hi
all Dax builders out their just about to wire lock the 3 front steering bolts and brake caliper bolts i had a few goes at it and it just douse not look right to me and if some thing douse not look right it normal is not ! can any one post a picture or a drawing of how the layout should look ? thank you oiler0 |
Wire Locking standard
Have a look at the following link. This gives a typical standard as used in the aviation industry. The principal of all wire locking is that it is holding the bolt or nut in a positive tightening direction. You should have slack in the wire and you shouldn't over twist it so that it is likely to fracture.
Use stainless steel wire if possible as this will obviously not corrode. I think the wire you removed would have been about 0.080" thick. If you can use some more of this use it but it will be tough to fit and twist. I used 0.032" wire on mine and I can assure you it will be fine. I work in aviation and use wire locking pretty much every day so it is like second nature but I can appreciate that it does take a bit of practice to make it look neat. One tip, make sure when you do your final tie off bend the wire back on it's self so that you don't have a sharp edge sticking out, otherwise your hand will find it at a later date and it is sharp enough to puncture skin! Neil Oh yeah don't forget the bolts on top of the diff are wirelocked too. Lockwiring Aircraft
I should be called "Nearly There" But I was drunk when I joined this club! |
thank ,s for that just what i was looking for
it looks like i got it all wrong ? i work in the same as you do i got hold of some 0.032 out of shelf life s/steel wire all good fun trird time lucky ? |
Nice link, and welcome to the mad house
Noel Sumo,BAE Chevy 383 Stroker/Roller cam , If it's not broken....fix it until it is? Gallery: http://www.cobraclub.com/gallery/sho...63&page=0&sort= |
Very nice Russ, That's how they should look.
I let my father do mine as he's an engine and airframe engineer at British airways so has plenty of experience. He used the proper twisting pliers and ended up with something looking as good as yours. You should have seen the wire that was on my donor parts before I stripped it down. It looked more like farmer Giles efforts at fencing wire! Craig.
Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 14
Thanks for the kind words Craig, I have had several years experience in wire locking. I was an aircraft engineer in the Royal Navy for 12yrs working on Sea Harriers, which has alot of bolts and nuts!!! I also have a pair of "Rolls Royce" wire locking pliers, which make things a little easier.
Russ
DAX DE DION - HUDDART 383 - 452bhp & 466lbft Torque |
Airman
Neil
| Locking brake pipes to the Calipers | chedz | Pilgrim Sumo Technical Questions | 3 | 21-06-07 09:40 AM |
| Brake caliper slide | malcolmbuck | Pilgrim Sumo Technical Questions | 9 | 23-01-07 07:03 AM |
| Jaguar brake caliper spacer | Speedy Gonzales | General Tech Tips & Questions | 0 | 10-10-06 09:26 AM |
| Safety Wire Locking | Robin427 | General Tech Tips & Questions | 1 | 01-07-03 08:33 PM |
| Brake Caliper Size Fittings | BenBaron | General Tech Tips & Questions | 9 | 17-02-03 09:44 PM |
