Results 1 to 4 of 4
  1. #1
    richard mason is offline Mechanic
    Join Date
    Aug 2007
    Location
    Rugeley , Staffordshire.
    Posts
    315
    XJ40 Handbrake Shoes
    Anyone got details of the shoe, springs, handbrake mechanism (inside brake drum) please? I am not sure mine have been correctly fitted and would like to check. Mine has vented rear discs but I think the handbrake is the same
    Any help, piccies, much appreciated
    Richard
  2. #2
    Jeremy Oddie's Avatar
    Jeremy Oddie is offline Tyre Kicker
    Join Date
    Jan 2008
    Location
    Cheshire
    Age
    54
    Posts
    32
    XJ 40 Handbrake shoes
    Hi Richard, these may be of some help
    Jeremy
    Got there...3 years and worth it.
  3. #3
    Join Date
    Aug 2007
    Location
    Posts
    315
    Quote Originally Posted by Jeremy Oddie View Post
    Thanks Jeremy, mine are different but it proves that I have the spring on the adjuster side right, as yours are in the same configuration. I was concerned that it was hard up against the adjuster wheel and now realise it's ment to hold the adjuster wheel slightly. It's just enough to stop it turning due to vibration etc.
    Cheers Richard
  4. #4
    Join Date
    Jan 2008
    Location
    Cheshire
    Age
    54
    Posts
    32
    Hi Richard, glad the piccies helped
    Jeremy
  1. XJ40 handbrake cables
    By Daxman in forum DAX Technical Questions
    Last Post: 04-04-07, 09:31 AM
  2. Magic shoes
    By Dutch Paul in forum The Cockpit
    Last Post: 02-09-06, 06:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
