| What a pain in the ar$e. Not seen or heard of theat one before Rob, I would just sort the one side if the other looks OK at present.
__________________ Brian DB Replicas Dax-No 54 - 2003 Modified by me - 2008/9 383ci SBC upgraded by Clarkson - 2008 Delivers Maximum Smiles Per Mile |
| Looking at the pic again it looks like your end cone is working its way out of the pipe. Worth checking to see if it is fixed properly.
| Thanks for the advice chaps, will take off the end caps and get both sides welded just to make sure they stay put this time.
__________________ DB Replicas Dax De-Dion 427 - Build 109 Mike Huddart 383 Stroker |
| Agree with Brian, Check there is a fixing in the end of the side pipe holding the tail pipe in. Without that the weight of the pipe will twist the end cap round and twist the bracket off the side of the tail pipe. I have a stainless nut welded inside my tail pipe and a hole drilled in the underside of the side pipe. A small stainless dome head screw holds it all in place. There are various pictures of my sidepipes in the Cobra club Wiki. Cobra Wiki Craig.
__________________ Dax Tojeiro, + 355 Chevy + Tremec box = no more money! TWM Fuel injection now up and running! Sounds and runs superb. Polishes to date = 27 |
| Quote:
| Hi rob, doesn't look like a major job. You could probably just get it tig welded no problem. Either that or undo the end bit and fling it back to dax and ask for a replacement. Quickest solution is stainless weld it tho. if you need any bolts etc pop down see me i've got loads of stainless Si
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| Quote:
Eggs, teaching, suck and all that but it may be best to set up the exhaust on the car and put a couple of tacks on that mounting plate in situ. I say that as the bracket plate comes out at a funny angle and will be difficult to get right freehand...
__________________ Pete SAY NO!... TO GAY FIBAE SBC 350 / TKO500 / 3.54PL - Less of a mess now but still plenty to do... Number of polishes - 1/2 and a bit... If I'd known I was going to be so thirsty this morning I'd have drunk more beer last night. |
| Quote:
Hi Rob, Which is the PS1 Qatar. As you can see from my profile I am based in Doha itself. It's 46 degrees this afternoon with the visibility down to half a mile due to the dust. No fun at all!!!! Cheers Rob
__________________ Rob RAM 427 SC-R (aluminium) Don't drive faster than your guardian angel can fly |
| Quality driving | kevchard | The Cockpit | 2 | 04-06-09 03:44 PM |
| dax radiators / quality issue? | v8amp | DAX Technical Questions | 22 | 03-12-08 10:58 PM |
| Quality vid clip!!!!!!!! | salypenter | The Cockpit | 0 | 06-09-06 10:38 AM |
| Quality of body... | Keith1968 | Newbies | 12 | 11-06-06 10:43 AM |
| quality badges? | Cobra power | General Tech Tips & Questions | 15 | 17-09-05 02:51 PM |
