I've fitted one of those and yes it can be bolted to the footwell front.
Andi.
Hi all,
Who has fitted on of these in place of the Ford Aluminium bracket?
Bearing part No. SLFL25 from
Revolution Seals & Bearings Ltd
Unit J, Houndswood Gate
Harper Lane, Radlett
WD7 7HU
01923 858385
Article on Robin Hood site
Supporting the steering shaft
There is far too much play in my bush (Hmm.... sure there is a joke there) and I'm considering replacing it with a SLFL25.
Does anyone have any photos of one fitted?
Is there enough rotation from the spherical outer of the bearing to bolt the two retaining plates directly to the bulkhead or do I need to fabricate a plate like the existing Dax item to hold the new bearing?
John
If you drive a Cobra you are going to get wet.
Dax Toj 350ci Chevy, Tremec TKO600, 5" Sidepipes
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ - http://www.tomsrush.blogspot.com/
Dax Tojeiro, Chevy 350, Tremec TK05, 3.54 Powerloc diff. MoT'd, SVA'd, registered, taxed and insured. Now with RAC cover, just in case
Polishes to date = 7. Engines to date = 2. Seats to date = 4. Sold
Rules for buying 'Go Faster' parts:-
If it's fast and cheap then it's not good.
If it's cheap and good then it's not fast.
If it's good and fast then it's not cheap!
Thanks guys,
That Photo confirms what I thought , bolt it straight to the bulkhead.
I've just sent Revolution an E-mail to get cost and then I'll be ordering one.
John
Here's a pic of one in my Robin Hood which shows it will easily meet the angle you will require.
Cheapest place I could find was here Bearing Boys :: for all your bearing and power transmission needs :: SKF Ball Bearings, Vee & Wedge Belts
Cobra not quite as shiny as my head![]()
Just to be different I bolted my bearing to the aluminium bracket supplied by Dax. I already had the holes in the bulkhead for that anyway so I didn't want them to be visible.
The bearing will fit on the aluminium bracket if it's mounted at an angle across the plate and it keeps it more in line with the column.
I'll take pictures some time if you like.
Polishes to date = On hold.
If I remember correctly I bought and fitted to my old Sumo the exact same bush from RS spares!
BIG TONE
AK build Updated 25/4/11 Body now on!My Gallery
Much better than the standard Dax set up. Like Tone I got mine from RS Components.
Lloyd B
Hello John,
I also used the RS components bearing, it's a lot better than the Dax one. Hope the pics help mate.......
Ian![]()
CHUNKY******ANOTHER IAN (454) Build it slowly, Drive it very Quickly.
Bookmarks
