Results 1 to 6 of 6
  1. #1
    oiler0 is offline Mechanic
    Join Date
    Mar 2005
    Location
    BERKSHIRE
    Posts
    434
    Dax transmission tunnel and dash problems
    i got 2 problems ,,,some would say more than that ?
    the dash i received from DAX as you can see has a piece broken off
    i presume this is not right and i should of complained at the time
    when it was sent to me but it,s way to late for that as it was 20 years a go.
    will the broken piece be a problem when it comes to fit the dash ?
    and is the back of the dash supposed to have plastic spacers on the back !
    second problem is the transmission tunnel dont fit
    i have a mk3 chassis that i modified to mk4 chassis by fitting the back bone brace supplied by DAX
    my body is a mk4 1991 and was supplied with the transmission tunnel at the time
    at the dif end where the back bone brace fits to the chassis the bars are about 10 inch apart
    but the fiberglass tunnel is only about 6 1/2 inches wide at that point
    so is their a different transmission tunnel for a mk4 body with a back bone brace fitted ?
  2. #2
    Lloyd Barnes's Avatar
    Lloyd Barnes is offline Technical Director
    Join Date
    Nov 2006
    Location
    Shropshire/Wales Border
    Age
    42
    Posts
    3,935
    The one I got from memory looked quite a bit wider than that at the rear, worth asking Dax. However I have to say the fit was comically bad when I received it from Dax. I had to make extensive modifications to the tunnel to get it to fit at all.
    Lloyd B
  3. #3
    craggle is offline Driving God
    Join Date
    Oct 2003
    Location
    Southwater, West Sussex
    Age
    36
    Posts
    9,866
    That bit is supposed to be on the end of the dash but it could simply be rebuilt with glass fibre matting and resin, Looks a different design to the current one though so maybe make another or buy the later version from Dax.
    I reckon those plastic tubes are pushed over threads and there to protect the threads from resin whilst being made, Cut around the base with a knife and pull them off then pass the studs through holes in the body to attach the dash.
    There is a 2 piece transmission tunnel to the later design available from Dax to cover the backbone brace. Not sure if the front section is a different shape though but if it is, maybe that new dash panel will be needed to match?
    Polishes to date = On hold.
  4. #4
    Mike Read's Avatar
    Mike Read is offline Chief Bottle Washer and Tea Boy
    Join Date
    May 2009
    Location
    Adelaide, Australia
    Age
    59
    Posts
    109
    You are missing quite a lot of the dash ... most of the steering cut out and right side. Pic attached of my dash being trial fitted.
    The current tunnel, front and back, is much wider as per the attached pic ... you can see that the rear part is a pretty poor fit, as Lloyd says! It needed a heat gun and lots of pressure to get it into the proper shape!
    Unless you are an ace fibreglass fabricator, I suggest you speak to Dax about the broken dash ... looks like you might need a new replacement ... and whether you can get away with just replacing the rear section of the tunnel. If you need new parts, perhaps they might reduce the cost if you mention goodwill for being a 20 year customer! No harm asking!
    Regards, Mike
    Dax Rush IRS, 4.8 litre Rover V8, R380 5 Speed, 321 bhp, 325 lbs/ft of torque (SOLD)
    Dax 427 DeDion, 7.0 litre GM LS7, Tremec 6 Speed Magnum TR6060, 571 bhp, 530 lbs/ft of torque
  5. #5
    Fireball-XL5's Avatar
    Fireball-XL5 is offline Spanner Holder
    Join Date
    Apr 2011
    Location
    Bishop Auckland
    Posts
    85
    I think his email only receives, I would ring him.........
    James G
    Purple Dax / Ford 260/4 speed toploader all in need of TLC and cash but the dreams are there.
  6. #6
    Join Date
    Mar 2005
    Location
    BERKSHIRE
    Posts
    434
    thanks guys
    i will indeed phone Dax to see what he can do about the dash bit out of order me think i wish i complained at the time
    will be going for a trial fit of the body soon i just know it will be problems !!
    thanks for the pic,s big help and i know where to put the rivets now to hold down the body
  1. Securing Dash to Centre Tunnel
    By britainj in forum AK Technical Questions
    Last Post: 10-08-10, 06:51 PM
  2. transmission tunnel - rear cover
    By Daxman in forum DAX Technical Questions
    Last Post: 20-11-06, 10:10 AM
  3. Transmission tunnel
    By richc in forum DAX Technical Questions
    Last Post: 29-10-05, 11:12 PM
  4. Gearbox / transmission tunnel clearance
    By marcel in forum General Tech Tips & Questions
    Last Post: 26-11-03, 11:53 AM
  5. Transmission Problems
    By barrie in forum General Tech Tips & Questions
    Last Post: 10-05-03, 04:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
