| DAX, Rover gearbox (lt77) mounting issue... Hi all, I have just put in my engine this morning, RV8, and when putting on my gearbox have run into a slight problem. The Dax supplied plate that the mounting from the gearbox bolts overhangs the mounting 'shelf' by about 2cm..... piccy attached to try and explain what Im on about... Have I bo**oxed up the gearbox mounting in sumway, or is it supposed to be like that (not very stable though....) Any pictures of a Rover mounting would be much appriciated... Cheers Ben |
| RE: DAX, Rover gearbox (lt77) mounting issue... Hi Ben mine was exactly the same, all i did was chop some material off the ends until there was no overhang, (angle grinder should do it). regards |
| RE: DAX, Rover gearbox (lt77) mounting issue... cheers Tom, thats what I'll be doing then |
| RE: DAX, Rover gearbox (lt77) mounting issue... Why not just make a new hole ?? seems like grinding off bit's is causing youself extra work |
| RE: DAX, Rover gearbox (lt77) mounting issue... holes still have to be drilled, but the plate was slightly too wide...... |
| lt77 gearbox | markg | General Tech Tips & Questions | 5 | 24-02-04 05:42 PM |
| Rover LT77 Gearbox | chesterak | General Tech Tips & Questions | 14 | 08-01-03 10:05 PM |
| Rover LT77 gearbox mounts | DrFelch | General Tech Tips & Questions | 6 | 10-12-02 11:51 AM |
| Rover Gearbox Mounting... | sideoiler | General Tech Tips & Questions | 3 | 07-11-02 08:21 PM |
| Rover LT77 gearbox oil | chesterak | General Tech Tips & Questions | 4 | 19-06-02 09:51 AM |
