  #11 (permalink)
Old 17-01-03, 09:35 PM
STEVE G's Avatar
RE: Dax Radiator (SD1) mounting sizes
F**k me with them fans you wont need an engine
Steve G
GRAVETTI 427-Rover 281ci.
Regards Steve G
  #12 (permalink)
Old 17-01-03, 09:41 PM
Cobra289's Avatar
Hi Steve G,
I need the engine to run the alternator.
One of the fans is operated by the ECU and the other is operated by a switch.
Regards,
Cobra289.
Nobody can change your opinion!
If I can bring you to doubt, possible you will change your opinion.
http://www.donostia.demon.nl
Cobra289 Gallery
  #13 (permalink)
Old 17-01-03, 09:56 PM
Ben,
Don't know if this will help, but my Dax has a SD1 rad but the lower support bracket is attached to the chassis rail with a single vertical bolt each side as opposed to your sketch which shows a pair of horizontal bolts. Anyway the distance to the centre of the bolt is 110mm from the chassis front face.
martin
4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark.
  #14 (permalink)
Old 18-01-03, 09:28 AM
excellent thanx loads..
presumably then you didnt get the dax mounting (or maybe they have redesigned it?)
kreativejuice...
www.kreativejuice.co.uk
  #15 (permalink)
Old 18-01-03, 11:32 AM
Ben,
i bought my Dax last May as a part built so am not sure of the origin of the lower mounting but it looks a proper Dax part and fits the SD1 rad nicely. Mind you my chassis is of 1992 vintage so guess it has been redesigned. Shout if you need anymore info.
martin
  #16 (permalink)
Old 18-01-03, 07:34 PM
dave's Avatar
Tuuurn up da bass.
Yup!
It has been re-designed.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Wheel sizes? Stu J Pilgrim Sumo Technical Questions 10 30-07-07 02:52 PM
Sumo Radiator Mounting salypenter Pilgrim Sumo Technical Questions 13 02-05-07 09:57 PM
Radiator Mounting BenBaron DAX Technical Questions 11 04-03-04 09:14 AM
Sumo Radiator Mounting Dan General Tech Tips & Questions 6 07-11-02 09:22 PM
Dax Radiator Mounting dax427 General Tech Tips & Questions 6 02-07-02 11:10 AM
