Old 15-01-03, 09:46 AM
Dax Radiator (SD1) mounting sizes
Hello again,
I would like to mount my radiator (SD1) to my chasis so I can plumbe it up and get my engine in, but I dont have my body as yet and after reading the manual it says to mount as high up as possible without touching the shell (but I dont have it so Im stuffed).
So if any of you luvly people have the measurements I need, I would be V greatful..
I've attached a piccy of what it looks like to me, excuse the drawing though
well maybe not attached as it wont let me????
I'll respond to this with the attachment.
kreativejuice...
www.kreativejuice.co.uk
Old 15-01-03, 09:47 AM
RE: Dax Radiator (SD1) mounting sizes
here it is!
kreativejuice...
Old 16-01-03, 07:03 PM
Come on guys, has nobody built a Dax with a RV8 and an SD1 rad???
ok if not how about anybody with a dax give me the measurements I need and the height of you rad then I can work it out...
Please, please please please, begging see ;( ;( ;( ;(
kreativejuice...
Old 16-01-03, 09:24 PM
dave's Avatar
What's the point?
Hi Ben.
If you are using the Dax Rad Bracket then you should minimize length"A" and centralise "C" and "D".
This will work fine.............I think, i haven't built a Rover powered car since 1995.
If you dont min. "A" the return edge of the lower front of the body which curls under will foul on the rad.
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 16-01-03, 09:46 PM
dave's Avatar
What's the point?
Ben.
there is a picture on my website of where the rad bracket needs to be mounted.
Take a look in the gallery and then the "See a build" section
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 17-01-03, 10:28 AM
Cobra289's Avatar
Hi Ben,
Incline the radiator to the back of the car as far as you can.
My set-up is 10 degrees.
I have changed the situation because the top of the radiator has hit the body several times.
My experience is based on a DAX MKII and the left side of the body is lower than the right side.
The paint was cracked because of the hit with a large star (3” diameter)
The space between the body and the radiator with the 10 degrees angle is now 15mm.
I did also a radiator surrounding from aluminum with two blowers at the front (Push)
The blowers come from a Citroen BX.
I got the dimensions of the surrounding if you want.
regards,
Cobra289
Nobody can change your opinion!
If I can bring you to doubt, possible you will change your opinion.
http://www.cobraclub.com/crcforum/user_files/903.jpg
http://www.donostia.demon.nl
Cobra289 Gallery
"Improvement"¯ means that you recognize previous mistakes!
Old 17-01-03, 10:44 AM
Cobra289's Avatar
Hi
If you measure the picture of the build from Dave you can find the angle of 9 degrees.
I measure the angle between the overrides plate and the aluminum radiator.
Regards,
Cobra289
Cobra289 Gallery
Old 17-01-03, 07:27 PM
ahh right so I need to angle the radiator then?, didnt realise that from reading the manual, perhaps I read it wrong.....
thanx guys...
I can progress now
kreativejuice...
Old 17-01-03, 07:57 PM
Cobra289's Avatar
Hi BenBaron,
DAX doesn’t mention about an angle, but it say that you should install “as high as possible leaving a gap of just ¼” between the top corners and the body molding”
I prefer to get 15mm due to my bad experience.
Regards,
Cobra289
Cobra289 Gallery
Old 17-01-03, 08:09 PM
cheers for the info..
kreativejuice...
Wheel sizes? Stu J Pilgrim Sumo Technical Questions 10 30-07-07 01:52 PM
Sumo Radiator Mounting salypenter Pilgrim Sumo Technical Questions 13 02-05-07 08:57 PM
Radiator Mounting BenBaron DAX Technical Questions 11 04-03-04 08:14 AM
Sumo Radiator Mounting Dan General Tech Tips & Questions 6 07-11-02 08:22 PM
Dax Radiator Mounting dax427 General Tech Tips & Questions 6 02-07-02 10:10 AM
