| Header tank Just fitted the header tank to my 351w but not sure where to connect the top outlet from the tank. On the chevy it connects up to the small outlet from the thermostat housing. Any ideas?? |
| RE: Header tank Hi mike, On most production cars and i think kit cars you'll find the header or expansion tank connects to the radiator. |
| RE: Header tank The rad that dax supply has no other outlet other than the top and bottom hose connection and i have no other outlets off of the engine |
| RE: Header tank Hi Mike. Haqve you asked Dax if they can supply you with a stat housing with the outlet for the breather pipe? As one in the rad would be too low anyway, that's why they use a headder tank.
__________________ Pro Dax Builder Current builds:- Dax No.125---------Kirkham No. 1 Low Volume manufacturer |
| RE: Header tank Hi guys do you think this set up would benefit from a bleed valve in the top hose? |
| RE: Header tank Rocket I've just re-designed my cooling system.With ally rad that has an air bleed at the top that goes via a swirl pot in the top hose to the top of the header/expansion tank mounted on the bulkhead.At half full,giving plenty of room for expansion,the water level is well above the themostat housing and heater.So no need for any bleed valves.See "Back on the road" thread for report on first run impressions. Steve G GE427-Rover 281ci.
__________________ Regards Steve G GE427(Rover 281)Not blue-well a bit. |
| RE: Header tank Ha Ha......The fog is clearing.. got ya &V |
| Header Tank | stu e | General Tech Tips & Questions | 9 | 25-01-08 08:33 PM |
| DAX header tank | chesterak | General Cobra Discussion | 17 | 11-09-06 11:38 AM |
| Header Tank | bc_suv | Pilgrim Sumo Technical Questions | 5 | 26-03-06 08:06 AM |
| header tank | Rupert | DAX Technical Questions | 13 | 10-05-05 01:39 PM |
| Header Tank | mikey | General Tech Tips & Questions | 0 | 31-12-04 07:26 AM |
