| What does everyone else use as an accelerator cable? I have a SBC with Torker II manifold and an Edelbrock 1405 carb. I have had a devil's own job finding and fitting an accelerator cable to suit. The carb end is not too bad, but the pedal end is frankly a wobbly mess of brackets and levers. I just discovered last weekend that full travel on my loud pedal was only opening the primaries half-way, and the secondaries on the carb were staying firmly shut. I have modified the whole arrangement somewhat, but the secondaries are still only opening halfway and I just don't have enough room to modify my current set-up any further. I'll see if I can take some piccies and post them later. The good news is that I have discovered some major 'new' horsepower for the sake of an hours work and no money. Bet I wont repeat that very often any more... |
| RE: What does everyone else use as an accelerator cable? Thanks Dave! It all sounds rather easy and neat so I'll have to give it a try. Sure beats messing around the Halfords parts bin looking for a random cable that might fit... Will let you know how I get on. |
| RE: What does everyone else use as an accelerator cable... stefen I had a similar problem with the universal throttle cable and on searching the local breaker's yard found rather a neat plastic clip from a Peugeot 205. The end of the dax pedal needs to be modified slightly by reducing the thickness or you could trim down the plastic locking clip to fit. Also the ball on the end of the cable needs a slight tweak with a file to provide a pair of flats. Hope this is useful
__________________ martin 4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark. |
| RE: What does everyone else use as an accelerator cable... hopefully with a full attachment this time!
| RE: What does everyone else use as an accelerator cable? I measured the length I needed and ordered it from real steel. They are a pig and a compromise, I know. Mike |
| Accelerator cable mounting to Carb | peterol1 | Pilgrim Sumo Technical Questions | 7 | 21-08-07 07:17 PM |
| Accelerator pedal/cable | Kevin W | Pilgrim Sumo Technical Questions | 4 | 20-09-05 06:19 PM |
| Accelerator Cable fixing | BenBaron | DAX Technical Questions | 9 | 19-08-05 12:16 PM |
| Accelerator cable | bw41059 | General Tech Tips & Questions | 2 | 21-12-04 12:49 PM |
| Accelerator Cable | ss083 | General Tech Tips & Questions | 2 | 05-02-02 05:38 PM |
