| Fuel Tank Venting I was wondering how other DAX owners sort out their fuek tank vent. I have a flush filler cap and judging by the large gasp of air when I remove the cap, even after short engine runs in the garage, its definately not venting through the cap. As i'm using a non injection engine, I do have another pipe which is blanked off coming out of the tank, do I use that?
__________________ martin 4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark. |
| RE: Fuel Tank Venting No definately not, this is perely a fuel return for injection pumps. Your filler cap should be a vented type. If it is the aston or similar, look for a small hole in the brass circle that locates the rubber sealing ring. If there is not a hole, you need one. It is probably quite easy to drill one about half way between the rubber ring and the centre of the disk. Mike. Mike |
| RE: Fuel Tank Venting Sorted that problem now. Have brazed a small pipe near the top of the filler pipe and plumbed a pipe across the car cleated high up out through the wheel arch and down the chassis rail. Now onto the next problem!!
| Venting the fuel tank | kayjayd | AK Technical Questions | 12 | 18-10-07 07:27 AM |
| Sumo fuel tank and expansion tank, chevy pump | laosui | Parts for sale | 0 | 10-08-07 08:51 PM |
| Fuel tank venting | nbracken | General Tech Tips & Questions | 18 | 20-06-07 11:43 PM |
| venting the fuel tank | Cobra power | General Tech Tips & Questions | 3 | 20-02-07 06:48 AM |
| Non venting locking fuel cap | David Horsnell | General Tech Tips & Questions | 1 | 18-09-03 04:46 PM |
