Old 23-04-03, 08:44 PM
Another Dax Question! - wheel clearance.
Is it normal for the wheels to hit the anti roll bar on full lock when the chassis is supported on axle stands? I have just received the wheels (17") from Dax so the offset should be correct. Tyres are 235/45. Any ideas.
martin
4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark.
Old 24-04-03, 03:15 AM
dave's Avatar
I want to be a banana
RE: Another Dax Question! - wheel clearance.
Hi Martin.
I should know but i don't!!!!!!!!!!!
I have a rolling chassis at my workshop at the moment, give me a call during tomorrow (Or should i say today now?)daytime (I'll probably forget if you don't call)and i'll check it.
(07785 702005)
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 26-04-03, 10:12 AM
I am not positive, but I seem to remember the same happening to me when I got mine. I am fairly sure you are O.K. as when you get the weight on the car they just miss.
Mike
Old 26-04-03, 02:03 PM
Thanks for the info Mike, also thanks to Dave for his phone help on Thirsday. I asked Dax the question on thursday eveing also but no reply yet. I will try it with the weight on the wheels. One thing I did discover from Dave, his lastest build steering rack had 3 turns lock to lock with 10mm clearance on the anti roll bar, mine has 31/4 turns and no clearance, also very close to the upper wishbone.
martin
Old 26-04-03, 05:06 PM
Back on its wheels now, and it still hits!! . Anyone know about reducing steering rack travel?
martin
Old 26-04-03, 09:54 PM
kdavies3's Avatar
I've just fitted a new rack supplied by Dax.
And I dont have any problem with the wheels fouling the anti roll bar, at least not with the car on the ground.
Martin are you sure about your front wheel offset?
BTW I have 17" wheels.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 27-04-03, 11:58 AM
Thanks for that. The wheels were supplied by Dax last week, so should be correct, but just to make sure, I did some comparision measurements with the helpful Dave Brookes and the distance from inside of wheel/hub mating surface to rim edge was the same (145mm I recall). What year is your Dax chassis? and if you get a chance could you see how many turns you get lock to lock? I get 31/4 but Dave B's current build had only 3. My chassis (which i bought as a part built last year) is a 1991 Mk3 and the rack as supplied by Dax at the time.
martin
Old 27-04-03, 06:51 PM
kdavies3's Avatar
Mines a MK4 Dax with a rack supplied a couple of weeks ago.
I'll check out how many turns I have lock to lock.
Kev Davies
South Wales
Kev Davies
South Wales
Old 30-04-03, 11:41 AM
kdavies3's Avatar
Yup! 3 turns lock to lock.
Kev Davies
South Wales
Kev Davies
South Wales
Old 01-05-03, 12:43 PM
Thanks Kev. I did get a reply from Dax saying that clearances were tight but this should improve once the suspension has been set up. Somehow i think not!! Intend to have a close look at my rack to restrict the travel and if all else fails just have to spend some more money and get a new one.
martin
Tyres and wheel arch clearance qkingston General Tech Tips & Questions 1 08-11-07 04:17 PM
mystery wheel and soft top roof question hu0u20ba General Tech Tips & Questions 5 04-07-07 09:31 PM
GD Rear O/S Wheel clearance Grease Monkey General Tech Tips & Questions 4 04-06-06 04:27 PM
MKII Sumo Rear Wheel Ride Height/Arch Clearance Mike H Pilgrim Sumo Technical Questions 7 28-02-03 05:51 PM
Dax Clearance Question BenBaron General Tech Tips & Questions 32 07-11-02 08:25 PM
