| helllo Hello I am a newish member here I have been converted with the help of Peter Jones who has been brilliant help so far I was plning on building a pilgrim as it was the best I could settle for but now I am on the Dax track I am planing to use Rover SD1 v8 engine and gear box in my car but THERE IS A PROBLEM!!! the car I'm getting is second hand it has been in a prang on the track it is a body shell and chassis the chassis is ok butr there is some light damage to the rear and the front of the shell needs replacing can anyboby tell me how I can repair this and yes I need tchnical detail thank you Pictus
__________________ HAVE NOW GOT BODY ENGINE IS IN THE MIDDLE OF REBUILD WELL IT IS IN BITS NEXT TO RAD IN SPARE BEDROOM ABOUT TO REBUILD ALL 16 LIFTERS DUE TO CARELESS MECHANIC |
| RE: helllo Thanks for the advice can you tell me how easy is it to stick bits of body on also the car only has one hoop and I would like to fit two is it posible to get the extra supports to weld on
| RE: helllo I think you could weld in extra tube to support a second roll bar, but you either have to remove the body (not easy as it's riveted and glued on) or cut away some of the higher part of the boot floor, not a problem. to gain access to the chassis and replicate the other side.
| RE: helllo thanks I am actually removing the body from the chassis as I have alot to do to the chassis and the body needs some repair work
| RE: helllo When I visited Dax a while ago, they were repairing a crash damaged Dax in their shop. Basically, they will manufacture the bit you need, for example the front half of the wing, cut out the damaged area and graft in a new section. If you send them pictures of your damaged car, I am sure they will be able to make the bits you need. I imagine however, that the work involved scores 1 out of 10 on the 'fun things to do building a cobra'. Mark Smith Dax 383 Chevy Stroker/Tremec TKO Telford Shropshire
__________________ Mark Smith |
| RE: helllo yeah I phoned dax and asked them for advice and they are more interested in sending me the front half of the body from the door pilars and they say that it will sag basically they were rather negative on the subject of body repair also they are going to want me to pay through the nose for body repair and as you say it does rate very low on the fun-o-meter it will cost a lot less and I would like to spend more money in other areas
