Old 07-01-04, 01:26 PM
DAX Body Fixing
Happy New Year All
I'm about to fix the body to the chassis having first fitted the ally engine bay. I've got the Wurth but have a question on procedure. Is it best to drop the body on the chassis, correctly align, pre-drill through body and chassis rails, remove body, apply Wurth, drop the body back on then rivit & bolt down scuttle?
What preparation do you need to make to the chassis before fixing? Do you need to remove the powder coating from the areas where the Wurth is applied to help adhiesion? Do you need to remove grease etc. with some meths before applying the Wurth?
Help much appreciated
Richard
Richard
Dax - Standard Chassis, 383 Stroker (Tremec TKO v. soon)
Old 07-01-04, 02:05 PM
RE: DAX Body Fixing
make sure the body sits well on the chassis, and is square all round. I had to clearance a little around the roll bar tubes. Perhaps use mask tape, and make a few marks for critical alignment on chassis
leave the powder coat completely intact.
mask & mark up the chassis according to the dimensions in the build manual
clean with degreaser
apply worth where needed. protect the chassis/body with masking tape in areas where you think worth may get squished out
put on the body, pulling the body hard up against the chassis stops at the end of the footwells & align.
Drill and bolt at the ends of footwells, and a few strategic rivets at ends of runs. keep a rag to clean off the drill bit
Recheck alignment
If you're happy, continue to drill &rivet at end & middle of all rivet runs, and finally infill.
Oh - and get a decent drill bit (and a spare!)and a decent rivet gun
Remove any excess worth before its dry - its not coming off without a grinder once it is
Steve
GDEuro/LS6/T56 in progress
sgullick@waverider.co.uk
Steve - AC 04 COB
Old 08-01-04, 07:59 AM
kdavies3's Avatar
RE: DAX Body Fixing
Fully agree with Steve's comments, my only addition would be to work quickly because you want to get the all the rivets in and pulled down before the Wurth cures which only gives you an hour or so from memory.
It may be slower curing at this time of year?
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 08-01-04, 01:15 PM
RE: DAX Body Fixing
Oh dear thats me scuppered then, Ive never been able to work quickly!
will have to get some extra hands on the job then....
kreativejuice...
www.kreativejuice.co.uk
Old 15-01-04, 08:17 AM
RE: DAX Body Fixing
Thanks for the advice Guys.
Only an hour to drill and pull all the rivits. That sounds entertaining!
Richard
Richard
Old 15-01-04, 12:55 PM
RE: DAX Body Fixing
Does anybody know if they do a slower curing adhesive?
Im going to try and find out as I dont fancy my chances much.....x(
kreativejuice...
Old 15-01-04, 02:33 PM
kdavies3's Avatar
RE: DAX Body Fixing
I guess that as long as you get a few rivets in spread around various parts of the body, then the body will be pulled on to the adhesive, if it cures before you get them all in before it cures don't worry because it will be stuck like sh1T to a blanket.
Kev Davies
South Wales
:tu :tu :tu :tu :tu
Kev Davies
South Wales
Old 16-01-04, 08:57 AM
skorpion's Avatar
RE: DAX Body Fixing
Question...
Why not first fitting the body...
drilling...
removing the body and cleaning (removing all the metal parts residu from drilling)...
adding the sticky stuff....
rivetting...
This is the way they build aeroplanes.
Regards,
Andy
Dax Tojeiro de Dion
http://users.telenet.be/cobra427/
Body Fixing BenBaron DAX Technical Questions 2 22-04-04 08:00 AM
Preparation work prior to fixing down the body BenBaron DAX Technical Questions 8 02-03-04 07:14 AM
Dax Body fixing BenBaron General Tech Tips & Questions 23 15-12-03 10:16 PM
fixing points for body plz MARTIN123 General Tech Tips & Questions 2 12-05-03 09:56 PM
Sumo Body Fixing pgoodrum General Tech Tips & Questions 13 07-11-02 08:27 PM
