| Rover Engine + various Q1) Have been offered a Range Rover efi engine 250 sheets, 100k on clock prepared to rebuild it but is it different performance wise and bracket wise. q2) The caliper return springs, wheres the best place to attach those to the chasis?? Manual just suggests fitting them to the chasis near the calipers??! And Im not sure as to how crucial the positioning is. Q3)Engine lining, does that a) Need modification if fitting rover v8 for exhausts. b) need modification ie cut aways to butt against chassis upstands. c) How is the best way to fit them, nails, adhesive, rivets Yours in anticipation Thank you Mark :} |
| RE: Rover Engine + various Thanks Steve, Not sure if its cross bolted or just standard webs. Unable to get engine number until the seller comes home. The liner is engine bay liner stainless steel to admire my bald head in when it conks out again!!! lol |
| RE: Rover Engine + various If engine bay is already lined with s/s wot engine is in now?If no engine yet,make liners to suit<but i thought DAX made chassis to customer reqiurements.So engine mounts will be set for a certain engine. Steve G {-} GE427-Rover 281ci.(300+BHP)
__________________ Regards Steve G GE427(Rover 281)Not blue-well a bit. |
| RE: Rover Engine + various Steve, the engine bay of the range rover isnt lined at the moment. I have bought stainless liners from Dax for my engine bay. I have had the chasis made by dax to accept the rover v8 lump but my original engine is a bit more than shagged so i was looking towards another engine, hence being offered the range rover motor. I have also heard that there are problems associated with the linings provided by dax in some instances but i want to make sure that i am aware of these prior to assembling. Measure twice cock up once!!! |
| RE: Rover Engine + various That's true don't have the liners too close to the under side of the wings or you may experience stress cracking to the wings, due to body / chassis movement. Ideally leave about 5mm clearance to be sure. http://animatedgif.net/flags/-flags-uncat/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Rover Engine + various Mark, the block for the RV8 has not changed really at all except for changes in the oil pump but if the chassis was made for a RV8 then it will fit with no problems, except perhaps one which is the engine mounts but if they are different on the new engine just take the old ones off the original RV8 and fit them to the new Engine. Good luck MArtin :tu :tu :tu :tu
| Rover V8 - Where's the engine #? | AlexB | General Cobra Discussion | 15 | 13-01-08 10:07 PM |
| Rover v8 engine and box | Bodyshop Simon | Pilgrim Sumo Technical Questions | 5 | 07-01-08 11:48 AM |
| Anyone got a rover engine they don't want? | simon | General Cobra Discussion | 3 | 16-05-07 11:33 PM |
| rover v8 engine | will b | Engine Tech Tips & Questions | 11 | 07-05-07 03:46 PM |
| V8 Rover Engine | bendy21 | General Cobra Discussion | 18 | 07-11-02 08:13 PM |
