Old 13-03-04, 12:25 PM
Clutch Master Cylinder Pipework
I believe I have the standard Dax supplied Lockheed clutch master cylinder.
Has anyone changed from Hard copper tubing to –03 flexible tubing? If so, what adapter did you use? I cannot easily identify the thread (could be 7/16” UNF but not sure) & of course the adapter needs to be the correct profile to seal to the master cylinder take-off.
Thanks,
Baldric
Baldric
Old 13-03-04, 06:16 PM
STEVE G's Avatar
RE: Clutch Master Cylinder Pipework
Barry,not quite the same.Thes is a Girling m/cyl as supplied by Merlin.It has 7/16unf inlet(using -3 fittings and hose).The out to the slave is 3/8unf using -4 fittings and hose.
Steve G {-}
GE427-Rover 281ci.(300+BHP)
Regards Steve G
Old 13-03-04, 07:12 PM
Steve, Thanks for info.
What style of adapter did you use to seal to output port?
I was thinking of -3 fittings for my output, why are you using -4?
Baldric
Baldric
Old 14-03-04, 03:57 PM
STEVE G's Avatar
The output thread was 3/8 and that matched up with -4 fittings.Clutch is fine so cant be too far wrong.I think its a 3/8 male/male with statoseal washer and a -4 90 degree.
Steve G {-}
Regards Steve G
Old 15-03-04, 06:19 PM
Thanks for the help Steve,
Got it all sorted now. Could not understand how new adaptors sealed to the clutch port original seal face. Clearly they do not, instead they use a compression seal under the head of the adaptor.
Baldric
Baldric
Old 16-03-04, 09:09 AM
kdavies3's Avatar
I used a banjo connection on the outlet sealed with a couple of copper washers.
Kev Davies
South Wales
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 16-03-04, 10:42 AM
STEVE G's Avatar
Kev
I agree in hindsight that would be a tidier arrangement.
Steve G {-}
Regards Steve G
Clutch master cylinder stabber General Tech Tips & Questions 7 24-01-07 09:58 AM
Clutch master cylinder bogster DAX Technical Questions 1 20-11-05 09:21 AM
Dax Clutch Master cylinder V8bassman DAX Technical Questions 1 02-07-04 08:35 AM
Clutch master cylinder Stu Kaynes General Tech Tips & Questions 2 04-08-03 08:52 PM
Clutch master cylinder for a Dax PeteT General Tech Tips & Questions 2 30-08-01 11:28 AM
