| RE: Mounting Rear Diff The best way that i have found to fit the rear axle to the chassis is to assemble the wishbones onto the diff and slide the long pivot pins into the two holes then use a jack to lift the diff up to its top mount, it should go at this with only a little wriggling as the Dax chassis jig has a Jag diff welded into it. Good luck :tu
| jag diff mounting bolts WHAT SIZE ??? | zerocool | General Tech Tips & Questions | 1 | 29-10-06 08:06 PM |
| Diff mounting bushes | elbraiv | Pilgrim Sumo Technical Questions | 12 | 22-07-05 07:37 PM |
| Gearbox and Diff mounting | bc_suv | Pilgrim Sumo Technical Questions | 4 | 01-06-05 01:22 PM |
| Solid diff mounting | gwak76 | General Tech Tips & Questions | 23 | 08-09-04 08:28 AM |
| Diff mounting | gwak76 | Pilgrim Sumo Technical Questions | 2 | 18-06-04 10:33 PM |
