| RE: Sierra Column and switches. Yes, it is possible to use the later column and switches. The pin connections for the head lighting are slightly different. You will have to check it through with a meter to determine which pins do what. Best regards MarkT |
| RE: Sierra Column and switches. Do you mean that the pins are different to the fittings on the Dax loom ? If the mechanical stuff fits I should be able to sort out the electrics with a bit of sellotape and a scotch lock, I mean soldering iron and trip to Maplin.
__________________ If you can't fix it with a hammer it must be an electrical problem. |
| RE: Sierra Column and switches. As Mark said the later one can be used (I did it). The horn push is also in the steering wheel centre. Only minor wiring mods were required to suit the Dax loom. http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| Ford Sierra MK1 Stalk Switches Wiring Diagram | Scottieb | General Tech Tips & Questions | 1 | 11-04-07 08:15 PM |
| Sierra column switches | Daxman | DAX Technical Questions | 4 | 28-03-07 09:40 PM |
| Granada/Sierra Switches | Novacatt | General Tech Tips & Questions | 0 | 05-06-06 10:49 PM |
| ALLY & STAINLESS STEERING COLUMN SWITCHES | BILKO | General Cobra Discussion | 14 | 23-04-05 10:36 AM |
| Sierra column | Splitpin | General Tech Tips & Questions | 3 | 14-01-05 06:11 PM |
