Old 02-06-04, 12:30 AM
Dax fuel tank for 1991 Cobra
Can anyone recommend a supplier of a stainless steel or ally fuel tank to fit my '91 Dax Cobra ?
I can post some pictures of existing tank (which keeps blocking up fuel system !) if required. It is 57.7 cm long and 76 cm wide with rounded edges front and back, top and bottom. Sender centre is about 16 cm from front and 31cm from LHS. Fuel pickup is on RHS on top about 4 cm from front. Fuel filler is on RHS.
I have the car booked in with ShinyBitx for exhaust on 13th June, but was also considering AllyFab ( www.sales@allyfab.co.uk ).
Thanks,
Wires
Old 02-06-04, 12:46 PM
kdavies3's Avatar
Re: Dax fuel tank for 1991 Cobra
I would have thought that Roger was quite capable of fabricating a new fuel tank for you.
If the original tank is just dirty and not rotten with rust you should be able to give it a good internal steam clean to remove all the crud inside that's blocking the filters.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 07-06-04, 10:15 PM
madjohnny's Avatar
Wires, I have recently e-mailed Allyfab enquiring if they do a tank for a DAX, as soon I get a reply I'll let you know the outcome and pricing.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 08-06-04, 12:11 AM
Wires,
is that a tank with explosesafe stuff in it? Just interested.
Phil
5.0L TVR EFI Power
Old 10-06-04, 02:06 PM
Dear Chaps,
Thanks to everyone for the replies. I have the following info :
1. Roger at ShinyBitz (who is doing my complete exhaust system starting Monday 14th June) says that he can make a tank.
2. Roger reckons that it has the ExploSafe c**p in it and sometmes it breaks down and causes the sort of problems that I am seeing.
3. AllyFab will charge about £130 for making up my tank.
4. AllyFab say that the tank is a very strange size. I can post some pictures of the existing tank, if required. It is 57.7 cm long and 76 cm wide with rounded edges front and back, top and bottom. Sender centre is about 16 cm from front and 31cm from LHS. Fuel pickup is on RHS on top about 4 cm from front. Fuel filler is on RHS.
What do other people think ?
Regards,
Wires
Old 10-06-04, 08:12 PM
Wires,
why are you replacing it? If the explosesafe has broken down it can be removed, I know of two people who have done it and its cured the problem, fortunatly I didnt order one with the stuff in it so I dont have the problem,
Phil
5.0L TVR EFI Power
Old 11-06-04, 10:13 AM
kdavies3's Avatar
Another option is to use a stainless MGB tank I think it involves moving the filler tube though. Not a problem to weld it if it's new and never had fuel in.
Kev Davies
South Wales
fuel tank john w DAX Technical Questions 3 14-12-07 10:41 PM
Sumo fuel tank and expansion tank, chevy pump laosui Parts for sale 0 10-08-07 09:51 PM
Fuel tank sender/fuel gauge Dek General Cobra Discussion 3 16-05-07 10:34 AM
cobra fuel tank oiler0 General Tech Tips & Questions 2 09-03-07 04:44 PM
dax fuel tank oiler0 DAX Technical Questions 1 22-01-07 06:45 PM
