Results 1 to 3 of 3
  1. #1
    Pat's Avatar
    Pat
    Pat is offline Spanner Holder
    Join Date
    Oct 2003
    Location
    Cambridgeshire, United Kingdom.
    Posts
    89
    Suspension setup - again
    Yet another question about suspension setup. . . .
    Sorry
    I have a slight problem with my setup (I think), on acceleration all is fine and it
    behaves quite nicely.
    Under deceleration (lifting foot of loud peddle) a little more concentration
    is required to keep it on the straight and narrow.
    Tracking, toe , camber and castor as per Dax settings.
    No bump steer.
    Front: 235/60/15
    Rear: 295/50/15
    Any advice gladly accepted
    Blue skies,
    Pat
  2. #2
    Miket's Avatar
    Miket is offline Banned for being too old Pit Babe Magnet
    Join Date
    Jul 2001
    Location
    Newton Abbot, Devon, UK. (God's waiting room)
    Age
    64
    Posts
    13,133
    Re: Suspension setup - again
    Pat
    I would say the problem is your tyres are to big, my mate suffers from the same problem.
    215 front and 245 rear are plenty big enough for any Cobra.
    Mike
    Cobraless
    I've often been asked, "What do you old folks do now that you're retired?
    Well, I'm fortunate to have a chemical engineering background, one of the things I enjoy most is turning beer, wine, Scotch and margaritas into urine.
    Life's good, live it.
  3. #3
    Grease Monkey is offline Chief Engineer
    Join Date
    Oct 2003
    Location
    Bristol, UK.
    Posts
    1,958
    Apparently you need a bit of rear wheel toe in for stability under braking. I'd check this as well.
  1. Jag suspension setup
    By JR in forum General Cobra Discussion
    Last Post: 13-01-08, 10:11 PM
  2. suspension setup
    By wayne AK Lincolnw in forum Midlands
    Last Post: 24-12-07, 04:38 PM
  3. Suspension Setup
    By ptsrv8 in forum General Cobra Discussion
    Last Post: 13-06-05, 12:23 PM
  4. Suspension Setup
    By JOHN C in forum General Cobra Discussion
    Last Post: 14-03-05, 01:31 PM
  5. Suspension setup for a Dax
    By Philip in forum General Tech Tips & Questions
    Last Post: 23-05-03, 06:30 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
