Results 1 to 9 of 9
Thread: Brakes
  1. #1
    Pat's Avatar
    Pat
    Pat is offline Spanner Holder
    Join Date
    Oct 2003
    Location
    Cambridgeshire, United Kingdom.
    Posts
    89
    Brakes
    Can anybody advise please??
    I have recently replaced my calipers and rebuilt my master cylinder (morris marina), but I can't seem to get a firm pedal. Have now bled the system 5 times. . .
    The brakes still feel spongey and am at wits end.
    There was no scoring or damage on the internal of the cylinder, so quite sure thats not it.
    Kind regards,
    Pat
  2. #2
    MacGD016 is offline Mechanic
    Join Date
    Mar 2004
    Location
    Bristol.
    Posts
    313
    Re: Brakes
    If you replaced the pads they may take some time to bed in.
  3. #3
    Pat's Avatar
    Pat
    Join Date
    Oct 2003
    Location
    Posts
    89
    Re: Brakes
    Alas, no, its not the pads - those I've replaced a month ago
    and had been bedded in.
    Must be air in the system - some where???
    Have even left the brake pedal braced down for the weekend,
    and their still spongey. . . .
    Any further & all advice greatfully accepted!!
    Blue skies,
    Pat
  4. #4
    dodger's Avatar
    dodger is offline Chief Bottle Washer and Tea Boy
    Join Date
    May 2004
    Location
    Surrey/Kent borders,uk.
    Posts
    202
    Re: Brakes
    Just a thought,
    Make sure your calipers are the right way up with the bleed nipples at the top otherwise you will always have air in the system.
    Roger
    Magnum MkI
    Still looking for the Last Open Road ! ! !
  5. #5
    Pat's Avatar
    Pat
    Join Date
    Oct 2003
    Location
    Posts
    89
    Re: Brakes
    Yep - right way up
    Bleed nipples at the top
    I have heard people mention it can be a bit of a nightmare to bleed jag brake systems. Having rebuilt the system on both a friends and my own landys with no problems, I am starting to get a little confused.
    Keep'm comin.
    Blue skies (maybe not so??),
    Pat
  6. #6
    kdavies3's Avatar
    kdavies3 is online now Driving God
    Join Date
    May 2004
    Location
    Cowbridge, Vale of Glamorgan, South Wales.
    Age
    55
    Posts
    6,848
    Re: Brakes
    Are you bleeding with a power bleed or just the old fashioned way?
    I always use the old method using an assistant to pump the pump the pedal, whilst I lock off the nipples at the appropriate times.
    I bled my mine about 3 or 4 times to get a really good pedal. Mine uses a Ford cylinder / servo as supplied by Dax. :thumb:
    Kev Davies
    South Wales Area Rep.
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE, Old School Now Running and Driving
  7. #7
    Pat's Avatar
    Pat
    Join Date
    Oct 2003
    Location
    Posts
    89
    Re: Brakes
    Have tried both & even got a mate to have a go. . . .
    Still no luck.
    Took apart the master cylinder again and seals are
    the correct way round and in the correct order.
    Aaaaaaaaaaaaahhhhhhh
    Pat
  8. #8
    Join Date
    Mar 2004
    Location
    Bristol.
    Posts
    313
    Re: Brakes
    Pat, I guess you will have tried all of these but when confused I go right to basics so for what its worth here is what I would look at:
    Stationary checks:
    • You say the brakes are spongy but do they pump up? I have sometimes found that I get super critical and later find that they were fine after all!
    • Is there any ‘small’ sign of brake fluid round any of the unions or bleed nipples? Just the slightest dampness will mean that air is getting in
    • Have you got the pads in the right way round?, I once put some pads in wrongly so that part of the metal backing was in contact with the calliper, the car stopped ok but it felt like there was air, spongy brakes!
    • When you bleed them does any air come out?
    Checks on the road:
    • When you brake does the car pull one way; does one side lock up; does the back or front lock up? Any of these symptoms may point to where some air is in the system
    • Do the brakes improve if you pump them? Defiantly suggests air, not much help except to confirm that there is air in there!
    • Is there anything else different from before?
    Mac
  9. #9
    Join Date
    Jul 2004
    Posts
    1
    Re: Brakes
    I had a similar problem on a dax using an mgb tandem master cylinder, no air came out when bleading the old fashioned way but couldn't get a hard pedal. Eventually found a bit of scoring which had damaged the new master cylinder seals, removed this with a bit of wet & dry then fitted new seals. Pedal still doesn't feel rock hard but brakes work spot on.
    best of luck
    simmo
  1. Which Brakes
    By r0lex in forum Pilgrim Sumo Technical Questions
    Last Post: 17-07-05, 08:29 PM
  2. Brakes
    By Pat in forum DAX Technical Questions
    Last Post: 23-04-05, 01:32 PM
  3. Jag brakes
    By kev in forum General Tech Tips & Questions
    Last Post: 21-11-03, 04:25 PM
  4. AK BRAKES
    By STRAIGHT CUT in forum AK Technical Questions
    Last Post: 11-08-03, 09:17 PM
  5. 'kin Brakes
    By STEVE G in forum General Tech Tips & Questions
    Last Post: 03-03-03, 09:35 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
