| oil pump bolts I have 2 oil pump bolts with knackered heads so cant use a spanner or sockect on them also they are a pig to get at with mole grips/etc. I need to get them out so any ideas are welcome I even tried to get in with a junior hacksaw to cut the heads off and then remove the studs once the pump is removed but cant get in with the hacksaw. I am replacing the complete pump so I dont care if the old pump gets butchered, so all ideas/experiences welcomed Dave |
| Re: oil pump bolts Not sure if you've already tried it but can you get the hacksaw in from another angle to try and make a slot for a screwdriver? Last resort I know of is to punch a dent in the top and take a big drill to the top and drill the heads off. Good Luck. Craig. |
| Re: oil pump bolts Hi Dave If you have a welder, weld a nut to the head, i.e. in the centre, protect machined faces from splatter. |
| Re: oil pump bolts If you can't losen them with a chisel, drill the heads off. :thumb:
__________________ Stan |
| Re: oil pump bolts Techniques i've used in the past include: Cut a slot for a big screwdriver Angle grind the head off Drill the head off Hammer a slightly smaller socket onto the bolt head
| Re: oil pump bolts thanks for all the tips. got the bolts out and the new pump is in and running. Before the new pump I had 30psi when cold, about 22 psi when hot and 15 psi on tickover With the new pump I get 40psi on cold 30 psi when hot and around 24 psi on tickover I still get overheating probs when engine under load so now suspect a dizzy timing problem Dave |
| Re: oil pump bolts have you tried a smaller diameter pulley wheel so your water pump is turning faster ie the vitesse one is a lot smaller than the standard sd1. Bill |
| Help with Bolts for SD1 | martin_t | Engine Tech Tips & Questions | 16 | 11-07-06 11:34 PM |
| Con Rod Bolts RV8 | craizy | Engine Tech Tips & Questions | 2 | 03-07-05 05:53 PM |
| Bolts | Goldie | General Tech Tips & Questions | 9 | 31-08-04 10:21 PM |
| Oil pump bolts | dave jenkins | Engine Tech Tips & Questions | 2 | 21-08-03 12:49 AM |
| Chevy 2 bolts VS 4 bolts | Jesus | General Tech Tips & Questions | 8 | 07-11-02 08:26 PM |
