Results 1 to 7 of 7
Thread: Fuel Pump
  1. #1
    stu e's Avatar
    stu e is offline Chief Engineer
    Join Date
    Mar 2004
    Location
    Paignton
    Age
    46
    Posts
    1,205
    Fuel Pump
    Hi
    Could anyone suggest what fuel pump I should use on a RV8 3.5, I've been having a few problems which I believe are fuel related. The Facet solid state pump I have at the minute seems pretty noisey,I can hear it with the engine running sometimes, which seems a little too noisey. I also may get a bigger engine in the future and I'm sure a bigger pump would be needed.
    Thanks Stu
  2. #2
    TINKA is offline Driving God
    Join Date
    Apr 2004
    Location
    East Leake, Nottinghamshire, England.
    Age
    48
    Posts
    5,855
    Re: Fuel Pump
    I have heard before that the solid state one is not really up to the job, personally I used to use a Carter pump quiet and never gave me any bother at all.:thumb:
    Martin
  3. #3
    stu e's Avatar
    Join Date
    Mar 2004
    Location
    Paignton
    Age
    46
    Posts
    1,205
    Re: Fuel Pump
    Thanks for that.
    Could anyone suggest what pressure/flow rate I should be looking for, the carb is an Edelbrock 500 and where I can buy on from.
    Thanks again Stu.
  4. #4
    Join Date
    Apr 2004
    Location
    Age
    48
    Posts
    5,855
    Re: Fuel Pump
    I think if it gives more than 7 psi the float will be over powered normally an ideal pressure would be about 5 psi but is is not the only thing to take into account flow rate is just as important.
    Martin
  5. #5
    stu e's Avatar
    Join Date
    Mar 2004
    Location
    Paignton
    Age
    46
    Posts
    1,205
    Re: Fuel Pump
    Thanks Tinka
    I understand that pressure and flow are equally important, can anyone tell me what sort of flow rate I should be looking for, and can I fit a pump suitable for a 3.9 onto a 3.5 without causing more problems?
    Thanks Stu
  6. #6
    427scr's Avatar
    427scr is offline Mechanic
    Join Date
    Jan 2006
    Location
    Chilwell Nottingham (the nice bit)
    Posts
    418
    Re: Fuel Pump
    Quote Originally Posted by stu e
    Thanks Tinka
    Thanks Stu
    I use a Facet red top on a tuned 3.5 with SU's.
    It is well up to the flow rate, but you have to limit the pressure to 2psi or it over powers the floats in the carbs and floods the engine. You can do this with an adjustable fuel filter/pressure regulator fitted in line. You can buy these with a guage fitted. The instructions say that you should remove the guage when the pressure is set, but mine has been there for 16,000 miles with no problem at all.
    I don't know what pressure you should be running on your carb, but the info should be out there on the net.
    Oh, just one more thing, the Facet pumps seem to work better when they are mounted low down, near to the tank. They don't seem to like being in the engine compartment high up on the bulkhead.
    Cheers.
    Mark.
    1985 DAX 427, BMW Black, no scoop, no brightwork, 15" Revolution split rims, BFG boots, 3.9 Rover V8 ex Disco 9.35:1 with 4.6 heads, Hurricane cam, Modified SUs and other P6 bits and bobs. SS headers & side pipes, Jag/Jag uprated lowered springs, AVO shocks, Red Dot discs & pads, Toyota Supra CR high 5th box & special clutch.
  7. #7
    stu e's Avatar
    Join Date
    Mar 2004
    Location
    Paignton
    Age
    46
    Posts
    1,205
    Re: Fuel Pump
    THanks Mark
  1. fuel pump
    By lordy in forum Pilgrim Sumo Technical Questions
    Last Post: 12-08-05, 11:06 AM
  2. Fuel Injection fuel pump problem.
    By Poohbear in forum Engine Tech Tips & Questions
    Last Post: 11-05-04, 10:53 AM
  3. EFi Fuel Pump
    By SWP952 in forum General Tech Tips & Questions
    Last Post: 25-03-04, 02:09 PM
  4. Fuel pump
    By Shaney23 in forum General Tech Tips & Questions
    Last Post: 30-12-03, 06:03 PM
  5. Fuel Pump
    By Miket in forum General Tech Tips & Questions
    Last Post: 17-12-01, 07:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
