| Composite head gasket RV8 3.5 Hi Can someone explain the benfits of a composite head gasket to me please? I currently have my heads (standard sd1) in the machine shop being renovated and having new guides valves and springs put in. Do I need to have them skimmed as well? Do I need to skim the block faces (as I have read somewhere on the site)? Thanks Martin
__________________ GD427 Mk4 - Chassis rolling!! 3.5 RV8 - Engine in and running!! GD Chassis J0258. People who never make mistakes, never make anything!!! www.martins-cobra.co.uk |
| Re: Composite head gasket RV8 3.5 Quote:
Regards Martin
Is it just the block that needs skimming and not the heads? What needs taking off the block? Thanks Martin
| Re: Composite head gasket RV8 3.5 DO NOT skim the block (unless it's only a lick to clean it up). You should make the change to the heads (as the factory did). Your heads will then be transferable to any other block should you decide to 'upgrade' later. You need to take of 27thou to maintain original compression ratio and alignment of intake ports to manifold. You would be foolish not to make the change if your heads are already in the machine shop. The composite gaskets ARE measurably better at sealing both the combustion chambers and oil and water galleries. No need to change to 'stretch' bolts either unless you're buying new anyway. You can use your old style bolots and torque as per the tin gasket settings. You WILL need to re-torque once after 1/2 hour or so AND after first run though as the gasket will relax. If you use new stretch bolts and use the torque+ angle tightening regime then you will remove the need to re-torque. HTH Russ |
I thought If I just put the composite gasket on without doing anything all I would lose is a bit of CR? Maybe I should just stick to the tin one? Regards Martin
| Re: Composite head gasket RV8 3.5 Hi Martin, I ruined a good engine when the tin gasket allowed coolant to leak and corrode the pistons and bores. Russ really knows what he is talking about, have the 27 thou skimmed from your heads and fit the composite gasket, also use a composite manifold gasket. jeff
__________________ Jeff My next one is going to be AK |
The heads are still in the machine shop at the mo. Will go there tomorrow and get them to take 27thou off while they are in there. Thanks for the information on this and everything else, its a steep learning curve for me, but I'm enjoying it!! Many thank Martin
| Head Gasket - Not Cob Related | Martyn-ak427 | General Cobra Discussion | 30 | 17-01-08 10:13 PM |
| Composite head gasket rover 3.5 V8 | martin_t | Engine Tech Tips & Questions | 5 | 22-07-06 10:22 PM |
| Head Gasket set for 302 | Jason | Engine Tech Tips & Questions | 4 | 20-12-05 07:58 PM |
| Composite Gasket | MacGD016 | Engine Tech Tips & Questions | 4 | 25-04-05 09:09 AM |
| Composite Manifold Gasket | BenBaron | Engine Tech Tips & Questions | 5 | 24-12-04 08:08 AM |
