| Re: Rover V8 earth straps. Quote:
Maybe the people in the know didn't see it and it went off page 1. Any thoughts??
__________________ 1985 DAX 427, Black, no scoop, no brightwork, no paint, 15" Revolution split rims, BFG boots, 3.5SP6RV8 with modified 4.2 heads, modified SU's with K&N, Kent 180 over Rhodes lifters, SD1 chain cover / P6 water pump, SS headers & side pipes, Jag/Jag with uprated lowered springs, AVO shocks, Red Dot spiro discs & fast road pads, Toyota Supra CR high 5th box & special clutch. Looks like a dogs dinner, drives like it's taken 20 years to develop! |
| Re: Rover V8 earth straps. I'd think three straps are a bit of an overkill, but an additional one from say the engine mounting bolts in the block to a tapped thread in the chassis frame itself wouldn't do any harm. I've seen a few braided earth straps corrode and fail in the past, especially when subjected to vibration and engine movement so I'd go with an aftermarket plastic coated copper wire earth strap with soldered connectors at the end. Cheers, Tony
| Re: Rover V8 earth straps. Mark - the general rule is "if it ain't broke............." To be doubly sure, get a high quality voltmeter, set it on a range to show 0.5 volts or so, and check what voltage appears between the engine block and a convenient part of the chassis when the alternator is charging hard (e.g. just after startup). You should see about 150millivolts ish. Anything in the range of about 0.5 Volt drop means the earth lead has too high a resistance, and could do with being replaced with one of larger section, and the connections checking thoroughly for cleanliness. Even if you had three or more earth straps, I don't think it would improve the performance of your car one iota. In fact the actual extra weight of them might slow you down!
| Re: Rover V8 earth straps. The earth lead is already an aftermarket one and is in good nick. I'm with you on the weight thing, I make every attempt to slim components down wherever possible and the thought of adding two massivly heavy earth staps horrifies me............. So, if it ain't broke etc etc.
| tank straps... | Ricky | General Cobra Discussion | 13 | 22-01-07 09:23 PM |
| Check Straps | bobdude | General Cobra Discussion | 9 | 12-09-05 05:44 PM |
| Engine Crane and straps | tigerruss | General Tech Tips & Questions | 5 | 17-06-04 06:14 PM |
| fuel tank straps | jiz | General Tech Tips & Questions | 16 | 11-04-04 09:27 PM |
| Door check straps | David Horsnell | General Tech Tips & Questions | 4 | 17-10-03 09:10 PM |
