Old 09-07-06, 07:04 PM
martin_t's Avatar
Help with Bolts for SD1
Hi
Trying to source some stainless steel or galvanised bolts for my SD1 V8 Rover but am having difficulties. They are the bolts that hold the water pump to the timing cover/block. Firstly there are five 36.5mm (1.25inch) long bolts in the water pump of which I am not sure of the thread size (help please?). Also there are two 5/16 x 5.5inch bolts, one 5/16 x 5.75inch bolt and one 5/16 x just less that 5inch bolt. The long ones I obviously know the size I just need to source new stainless steel or galvanised ones (which is proving very difficult), but I need help with the size of the 5 small ones please. Any recommendations for the long ones would be much appreciated. Most people just can't seem to do such long ones.
Thanks
Martin
GD427 Mk4 - Chassis rolling!!
3.5 RV8 - Engine in and running!!
GD Chassis J0258.
www.martins-cobra.co.uk
Old 09-07-06, 07:45 PM
Re: Help with Bolts for SD1
The threads will be UNC; you may struggle to get such specific lengths from general fastener suppliers. I don't think you want galvanised, maybe zinc plated?
Myles D-W
Old 09-07-06, 09:49 PM
steamyrotter's Avatar
Serial Complicator
You might be better off using studding and nylocs.
probably the easiest and cheapest option.
cheers
Dean.
Old 09-07-06, 10:11 PM
martin_t's Avatar
Hi
Is that something that is commonly used?
Thanks
Martin
GD Chassis J0258.
Old 09-07-06, 10:19 PM
Serial Complicator
Not sure if its commonly used in general but I have used a similar tactic for some parts where there is not a long enough bolt readily available.
As long as you have the correct grade (8.8 equiv) and use a washer on each side it should be as strong, if not stronger, than a bolt of similar dimensions and specifications.
Studs are used a lot in flanged joints on pipe work and are the preferrred method rather than a bolt, as it gives more control on the stretch and hence sealing force on the jointing.
Also the stresses at the ends are lessened when using stud and nuts wrt Nut and Bolt. (the head of a bolt when tightened is subject to large stresses)
Dean.
Old 10-07-06, 06:40 AM
All things SD1 should go to Jim Robinson if he ain't got he'll know where to get it from
Old 10-07-06, 06:48 AM
martin_t's Avatar
Thanks
I have emailed Jim, just waiting for a reply.
Martin
GD Chassis J0258.
Old 10-07-06, 08:46 AM
CeeJay's Avatar
Have you tried eBay? There are usually several companies selling stainless steel bolt kits for the RV8.
CeeJay.
Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out...
Old 10-07-06, 11:37 AM
ybrikmr's Avatar
Just a thought but try real steel in Uxbridge middlesex 01895 422027 they build Rover and Chevy V8s.
Old 10-07-06, 11:54 AM
In my experience the best supplier is "Aidpac" in Birmingham - don't have the phone number handy but he advertises in the popular magazines. Has all RV8 sizes and is knowlegible and helpful. Real Steel are a pain in the ar*s.
Stan
Con Rod Bolts RV8 craizy Engine Tech Tips & Questions 2 03-07-05 05:53 PM
Suspension Bolts Phil McCann Pilgrim Sumo Technical Questions 5 09-05-05 05:16 PM
Bolts Goldie General Tech Tips & Questions 9 31-08-04 10:21 PM
chrome tee bolts macca Engine Tech Tips & Questions 1 11-08-03 09:05 PM
Chevy 2 bolts VS 4 bolts Jesus General Tech Tips & Questions 8 07-11-02 08:26 PM
