| Rover V8 Plumbing Never thought I would say this but I got the engine started and running for 5 minutes today. All I need to do now is a little tidying up in the engine bay. However I need some more help. There are a few "plumbing " tasks which I need to sort out but do not know what to do or "plumb" them into. I have one open "pipe" on each of the rocker covers (Breather pipes). What do I do with these??? Secondly there is a smaller pipe at the rear of the engine block (drivers side) which points upwards. What do I do with this??. During the five minutes the engine was running there was a little waft of something coming out of all three "pipes". The engine is an old P6 unit. Many thanks in advance Regards Denis |
| Re: Rover V8 Plumbing No idea what the pipe on the block is, I've never seen one on any of the RV8's I've had. Rocker breathers should vent into the air inlet, but I join mine together and run them into a catch tank, don't want gungy stuff going into my nice new heads now do I . Kev |
| Re: Rover V8 Plumbing one at the back i think is a crankcase breather
| Re: Rover V8 Plumbing The above plumbing is described in various threads on the forum. Basically it should be arranged so the crankcase pressure with oil vapours should vent to the carburettor after the air cleaner not through it and burnt in the engine. Clean replacement air should be drawn in through the other vent after filtration by the air cleaner. The result of this should create a slight vacuum in the crankcase. On an SD1 the larger piping goes to the carb body and the smaller to the air cleaner. Both pipes have suitable flame traps in them. |
| Re: Rover V8 Plumbing craigh, It may be a crankcase breather but what do I do with it?? The rocker breathers. Where do I plumb these to? Do I need flame traps?? Do I need PCV'S ? |
| Re: Rover V8 Plumbing pop a small filter on it,should do the trick
| Re: Rover V8 Plumbing Denis This picture may help a bit - you can see how the breather on the driver's side (European) has been plumbed in. Can't offer any technical advice unfortunately as I'm an engineer of the cheque book variety... Cheers Andy ![]() ![]() ![]() |
| Re: Rover V8 Plumbing Andy. Nice engine bay :thumb: But PLEASE change that fuel filter for something with a metal case
| Re: Rover V8 Plumbing Thanks for the Photo's Andy. Purple AK, Where do I source a metal bodied fuel filter?? Regards Denis |
| Plumbing | Green Power | Ram Forum | 7 | 04-11-06 02:52 PM |
| Rover Plumbing !! | The Pretender | Pilgrim Sumo Technical Questions | 19 | 22-08-06 04:01 PM |
| plumbing............ | h8jse | General Tech Tips & Questions | 17 | 26-04-06 07:59 PM |
| Plumbing | BenBaron | Engine Tech Tips & Questions | 2 | 20-03-03 09:24 PM |
| Rover V8 Plumbing | Dan | General Tech Tips & Questions | 5 | 07-11-02 09:22 PM |
