| Re: Valve Preload AGAIN....sorry! Quote:
| Re: Valve Preload AGAIN....sorry! Sorry to get slightly off the clearance subject but are these lifters servicable ?? I have one that if the engine stops in a certain place, ie with pressure on that lifter, its real noisy for a about 5 minutes. theres only one noisy one, and dont really want to change them all.... and the cam? Cheers guys, sorry for the interuption:thumb:
__________________ Cheers, Mark Not sure what drinks more petrol, the car or our cat!! |
Thanks for the well explained replies to my questions, I suppose my next question is, is there any point in using adjustable pushrods with hydraulic lifters or are they just ment for solid lifters? Cheers, Pete
| Re: Valve Preload AGAIN....sorry! To quote Myles, 'No advantage unless you are running very heavy valve springs and high revs. There is a disadvantage if they are heavier than standard because they add inertia which will cause standard springs to 'float' sooner.' I would add The only time I could think you might want to use them with hydraulics is if you've modified you head so much that you can't get in the acceptable (say 20-60 thou) range with std rods. You're pretty unlikely to need their additional strength or rev capacity with a hydraulic cam in any case. Russ ps I'm pretty certain in the factory not a single engine was ever checked for lifter pre-load prior to being despatched - the tolerances on the std Rover parts are such that the pre-load will work every time. |
| Re: Valve Preload AGAIN....sorry! Hi Pete. I may be completely wrong here, And I'm sure Myles will put me right if I am
| Re: Valve Preload AGAIN....sorry! Purple Chris is quite right; the correct length pushrods are needed to get the correct rocker geometry. As also mentioned above, you only need to worry about that if you have taken a big slice off the head and/or the block or if you were running exotic stuff like a reduced base circle cam.
| Lifter preload | tony | General Tech Tips & Questions | 3 | 23-02-04 06:49 PM |
| PCV valve to RV8 | Brian | General Tech Tips & Questions | 10 | 08-01-04 08:34 PM |
| RV8 PCV valve ? | Paul B | General Tech Tips & Questions | 4 | 29-10-03 04:07 PM |
| PCV valve ? | beanpole | Engine Tech Tips & Questions | 1 | 08-06-03 10:48 PM |
| Ford 302 valve preload | Rowie | General Tech Tips & Questions | 3 | 27-08-02 10:22 PM |
