| Hydraulic Clutch Problems Guys I have just fitted a hydraulic clutch conversion to my Sumo. The setup is a standard Rover V8 and SD1 gearbox. The problem I知 having is that I don稚 seam to be able to keep the hydraulic pressure in the system. If you press down hard on the clutch or pump it, the clutch operates and I can select a gear (with the engine running). If a leave the clutch for a while I have no pressure on the pedal. Or if I press down the clutch slowly there is no pressure. The master cylinder and slave are both new and I have bled the clutch several time so there is no air in the system and i don't have any fluid leaks I知 thinking the master cylinder is faulty (possibly the seals). What does everyone else think? Thanks Allan |
| Re: Hydraulic Clutch Problems Hi Wilf I don稚 seam to be loosing any fluid; I知 just struggling to keep pressure in the system? Regards Allan |
| Re: Hydraulic Clutch Problems Hi Allan Have you checked the joints in the pipe to see if any fluid is weeping out. I fitted the magnum kit and didn't get one of the olives tight enough on the flexi pipe which caused a leak. I also had to fit a 0.75 master cylinder as the 0.625 one suppled didn't move the slave cylinder enough to disengage the clutch Regard Stu |
| Re: Hydraulic Clutch Problems Hi Stu Yes I知 sure I知 not getting any leaks, I have checked and rechecked. The slave does move when the pedal is pumped (to get the pressure up). I have tried this several times with the engine running. The thing I find really strange is there is no back pressure on the pedal when you push it in slowly. If you push it in quick there is resistance and the clutch operates? Thanks, Allan |
| Re: Hydraulic Clutch Problems Allen. Is the bleed nipple on the top or the bottom of the slave? If it is the latter, You will never totally bleed the system. Just a thought :thumb:
| Re: Hydraulic Clutch Problems I helped Allan bleed the system earlier today. The slave cylinder was removed and held in such a way that the bleed nipple was uppermost so we're pretty sure that there is no air in the system. The master cylinder is dry and the joints seem dry too. Can anyone suggest a reason as to why the system works if the pedal is "pumped" rather than just pushed? :thumb: |
| Re: Hydraulic Clutch Problems Sorry - impossible to move a piston through a cylinder without displacing fluid and seeing a leak. Something is not right here. Can you observe the level of fluid in the reservoir when you push down slowly on the pedal? My guess is it rises, (and that is where the fluid is going) and that could well indicate a faulty master cylinder.
| Hydraulic clutch (again) | tonym | Pilgrim Sumo Technical Questions | 7 | 10-06-06 08:44 AM |
| Hydraulic clutch | tonym | Pilgrim Sumo Technical Questions | 5 | 04-06-06 07:04 PM |
| Hydraulic Clutch | Marty V6 | Pilgrim Sumo Technical Questions | 18 | 13-05-06 09:30 PM |
| Hydraulic Clutch help | jenny | General Tech Tips & Questions | 12 | 22-07-05 06:15 PM |
| Hydraulic clutch help | adricar2 | General Tech Tips & Questions | 3 | 24-05-04 08:49 PM |
