Old 05-12-06, 08:46 PM
oil temp sensors
Hello UK:thumb: I’m a new member from Scandinavian (sorry for my bad English) . I’m building a Swedish snake with a power plant from csb nothing special maybe 250 Hp.
My first question to you, where is the best place on the engine to mount the oil temp sensors for the gauge.
Old 05-12-06, 08:53 PM
craggle1
Guest
Posts: n/a
Re: oil temp sensors
Hi Joppe and welcome to the forum:thumb:
On my chevy 350 I fitted an oil cooler system so I mounted the temp sensor in the line between the oil pump outlet and the oil termostat. If you do not have an oil cooler fitted then I think the only place is in the sump pan.
Either replace the drain plug with a sensor or have an additional threaded boss welded on.
Old 05-12-06, 08:56 PM
SJ SJ is offline
I believe the most accurate place is on the sump but that requires welding. I've fitted an oil cooler and fitted an in line sender next to the thermostat, though this doesn't give a very accurate reading.
SJ
Old 05-12-06, 09:23 PM
craggle1
Guest
Posts: n/a
See post below
Old 05-12-06, 09:27 PM
Veteran polisher.
Heres a picture of my setup.
The two pipes come from the engine on the left. The block mounted on the chassis is the oil thermostat. The temp sender is in the top pipe that is the supply pipe to the thermostat. The two pipes coming out the thermostat going to the right of the picture, make there way to the cooler at the front.
Craig
Polishes to date = 17
Old 05-12-06, 09:45 PM
Clarkson's Avatar
Speed junkie
Craig
Looks nice mate!!
PS, is Craggle1 your brother by any chance??
David
2nd baby due 23rd Jan.
Old 05-12-06, 10:03 PM
As mentioned above the best place is the sump. You don't need to weld anything either. I just got a big nut & bolt which I had drilled and tapped then with some gasket paste and a brass washer I simply drilled a hole through the sump and did up the nut and bolt. Once it was in I fitted the sensor and left to set. Been in for 2 years and never leaked. :thumb: :thumb:
Old 05-12-06, 10:20 PM
Club Sec/Rep Liason
Oh Dear :rotfl: :rotfl:
AK 427 351C T5wc
Old 05-12-06, 11:50 PM
bogster's Avatar
Hi Joppe and welcome,
I fitted my oil temp sensor in the same place as Craggle, between oil outlet and oil stat as I have an oil cooler also. Otherwise its the sump.
Craggle, were did you get that nice conduit for your wiring? Looks great! :drive:
Bogster
Live the Dream
Old 06-12-06, 06:09 AM
Thanks for all answers. Did anyone check if the temp differ depending the alternative mountings. Thinking that the oil only passes the oil cooler when the temp is high enough in the oil thermostat. Or have the thermostat outside the engine a
by pass valve?
LS Oil & Water Temp sensors Happy Jim Engine Tech Tips & Questions 3 14-04-06 01:02 PM
oil/temp sensors qkingston General Tech Tips & Questions 0 11-03-06 07:39 PM
Lambda Sensors G4NLZ Engine Tech Tips & Questions 1 10-10-05 01:48 PM
VDO sensors qkingston Engine Tech Tips & Questions 0 20-06-05 11:51 PM
Gauges and Sensors MacGD016 General Tech Tips & Questions 1 01-04-04 07:01 PM
