| Re: V8 Head Bolts I used the assembly grease that came with the bolts, The reason for this is the torque figure quoted is not supposed to include the friction of the threads you would have if you use nothing. :thumb:
__________________ East Midlands Area Rep Martin Mega Squirt in and running ! Car Sprayed and looking Fab |
| Re: V8 Head Bolts Thanks Martin, Thats exatly what I thought, lube not sealer. I assumed that the head gaskets do the sealing and could not see a reason to seal the bolts. Thanks Bob
__________________ Sowing the seed for LeMans 2010 with the boss!!! |
| Re: V8 Head Bolts Don't forget that its not just the friction in the threads that can effect the torque reading. You must put some lube between the head of the bolt and the washer! Regards, Pete
| Re: V8 Head Bolts Hold on a second. On some engines, the cylinder head bolts go throught the block deck and into the water cooling spaces. Ford 289W comes to mind, not sure what others. Anyway - in those cases, a thread sealant is needed to stop water from getting up the threads and rusting the bolts solid in the block. (or leaking out through those threads).
| Re: V8 Head Bolts Quote:
I presume that as Bob (Oldcobber44) has put his question in the Rv8 section then he is talking about a Rover V8, in which case it is OK to use lube. Having said all that you still have a point. Regards, Pete
| Re: V8 Head Bolts Pete - you are right, I had missed that, and I can't recall if RV8 head bolts go through the deck or not. However, now that I AM aware of it, there is another issue - stopping the steel bolts from corroding into the ally block, and Rover specified some special gunk to do that. Really must stop to see where in the forum I am someimes!
| Re: V8 Head Bolts Wilf is correct (as nearly always Austin Rover manual says to "coat each cylinder head bolt thread with 3M EC 776 Lubricant-sealant" on the SD1 RV8. Best I could come up with was loctite stuff from Partco. :thumb: Robin
I was being a bit of a smart ar5e! and anyway from what Robin say's you need a special lube/sealant so we are both right and wrong in a way! Pete
| Re: V8 Head Bolts Many people have commented that I am "not right". Still, what do they know?
| Head, Con Rod & Mains bolts | dbm10uk | Engine Tech Tips & Questions | 4 | 27-08-06 08:11 PM |
| Alan head bolts | JonnyT | General Tech Tips & Questions | 8 | 23-11-05 07:53 PM |
| Head Stretch Bolts | roger | General Tech Tips & Questions | 4 | 05-11-04 10:57 PM |
| Head bolts | Paul B | Engine Tech Tips & Questions | 4 | 17-11-03 01:35 PM |
| What sealant to use on head bolts? | STEVE W | General Tech Tips & Questions | 5 | 20-06-03 06:59 PM |
