| Where can I get a 6 rib pulley?!?!?? Dear All Currently rebuilding a cut-out SBC350 and it came without a water pump pulley. Alternator and crank pulleys are 6 rib and the water pump is the long type. So, .... I need a 6 rib pulley for long water pump. But can I find one anywhere!!!! None of the usual suppliers appear to do them. Therefore can anyone suggest a supplier that can provide one of these hens teeth? FYI the engine is 1992. Thanks as always for your advice!!!:thumb: Regards John |
| Re: Where can I get a 6 rib pulley?!?!?? Quote:
| Re: Where can I get a 6 rib pulley?!?!?? Thanks for the input. Hmm. Thought about that but I think I would need new pulleys everywhere else and I can't get the pully off the alternator so I may have to get another alternator so I am currently trying to go with the 6 rib option. I'll check out the summit option........ |
| Re: Where can I get a 6 rib pulley?!?!?? Best place I can think of is Street and Performance @ http://www.hotrodlane.cc/. I have used them a lot and thier products are superb, always helpfull and I am sure they will be able to help with a single pully, good luck, Simon |
| Re: Where can I get a 6 rib pulley?!?!?? john the water pump pulleys where on the later engines not ribbed, the back of the belt drove them. the water pump was a reverse rotation pump and by changing it to a ribbed configuration it should run backwards, not particularly good.check you have the correct water pump and March make a set of ribbed pulleys .You can get serpentine conversion pulleys but you would need again a correct rotation water pump.if you need a price on a set of pulleys please send me an email. adrian
__________________ Adrian |
| Re: Where can I get a 6 rib pulley?!?!?? Hi John I will check the workshop tomorrow I may still have the old cast pump with the pulley. John |
| Crankshaft Damper & Pulley | steamyrotter | Engine Tech Tips & Questions | 3 | 27-01-07 10:05 PM |
| pulley diameters | apearce | Engine Tech Tips & Questions | 1 | 14-06-06 07:08 PM |
| SD1 Crank Pulley on a 4.6 | alastaid | Engine Tech Tips & Questions | 1 | 12-12-04 03:02 PM |
| Pulley Question | mikey | General Tech Tips & Questions | 1 | 01-11-04 06:03 PM |
| Idler pulley | andylester | Engine Tech Tips & Questions | 1 | 03-06-03 10:18 PM |
