Old 10-02-07, 07:36 AM
martin_t's Avatar
SD1 Rubber Sump gasket.
Hi
Can anyone tell me if the P38 rubber sump gasket will fit and SD1 sump? Been talking to Rimmer's and they can only supply cork for an SD1. They have P38 (Range Rover?) rubber sump gaskets, but they cannot tell me if it will fit my SD1 or not.
Thanks
Martin
GD427 Mk4 - Chassis rolling!!
3.5 RV8 - Engine in and running!!
GD Chassis J0258.
www.martins-cobra.co.uk
Old 10-02-07, 08:36 AM
russell_ram's Avatar
Club Treasurer
"They have P38 (Range Rover?) rubber sump gaskets, but they cannot tell me if it will fit my SD1 or not. "
They claim to be RV8 specialists but they can't tell you that ? ? ? ?
No it's won't fit. The main block skirts and rear bearing area are identical but the front cover area is a totaly different shape on post 38A concentric oil pump engines. In fact, early 38A type engines didn't use a gasket at all, the sump was sealed using auto grade silicon sealant. Only the later aluminium sumped engines took they rubber gasket with built in load transfers (compression limiters) because the sump was used to stiffen the bellhousing to block joint, utilising the bottom half of the bell housing as well as the top to get a full circle of bolts.
I wouldn't bother with the cork gasket either.
I have built dozens of RV8s and never use a sump gasket at all. A silicon joint is perfectly acceptable. You must make sure the sump face is fairly flat though - the bolt holes will be dished where previous owners will have over torqued the bolts to try and stop leak cork gasket from leaking - knock them back with a ball pein (sp?) hammer.
If you really want a cork or rubber gasket (but they'll both leak after a while) then I'm pretty sure Real Steel have both.
HTH
Russ
Sump gasket installation question.. Andy302 General Tech Tips & Questions 10 25-05-06 05:10 PM
Glueing rubber to rubber... Robin427 General Tech Tips & Questions 8 02-11-05 04:43 PM
Which Gasket?? jools Pilgrim Sumo Technical Questions 3 26-09-05 07:13 PM
Sump Gasket alastaid Engine Tech Tips & Questions 1 17-11-04 09:00 AM
Oil Pan Gasket Barry Smith General Tech Tips & Questions 12 11-02-04 08:08 AM
