| help required Due to a mishap with a speed hump yesterday, i am the proud owner of a diff unit with two stripped threads. The threads in question are at the bottom front of a Granada diff and are M12, the obvious answer is to get them helicoiled but this seems an expensive way to sort them out. The other possibility is to drill and tap them to M14. Can anyone else suggest any other options? |
| I assume you will need to remove the diff in order to repair it? If you take it to a local engineering shop they should be able to helicoil it just as cheap as drilling and tapping it to the next size up. M14 is not a common thread size and you will struggle to find bolts. M12 and M16 are the common threads. Unless you go to an imperial thread. 9/16 UNC or UNF which has a diameter of 14.3mm Craig.
| An M12 recoil kit (same as helicoil) is £35, you get the drill th etap the fitting tool the coils, its easy to do. Cromwell tools will sell the kit to you. And it makes a proper job no bodged up drilled bolts etc, and you will be able to take the bolts out later without sh1tting your self.
| Quote:
It's a Sumo, If it's raised any higher it will fall over in cross winds and people in Fiats will park underneath it.
| Quote:
| Carpets - Help required please! | Iain | General Tech Tips & Questions | 3 | 08-09-07 08:07 PM |
| PC Help required | jemburrett | Feedback, Membership and Help | 2 | 04-09-07 06:54 PM |
| Help Required | KooKooBean | General Cobra Discussion | 1 | 05-02-07 10:10 PM |
| Help required...... | Rat Boy | The Cockpit | 9 | 14-12-06 12:42 AM |
| Bit of sympathy required | Grease Monkey | General Cobra Discussion | 7 | 14-07-04 01:23 PM |
