Old 27-04-07, 06:29 PM
kobra's Avatar
Backfire
Started her up this morning and it started to backfire,but only onthe nearside pipe.After a few minutes it went away. On my return home it started ok but felt a bit lumpy. Any clue's please, The distributor was set to 36* and the fuel was weakened three weeks ago.uptill today everything was fine. Its done 1500 miles to date. Regards Ray
Old 27-04-07, 08:13 PM
Dutch Paul's Avatar
Re: Backfire
Firstly, check the distributor hasn`t come loose and turned a little.
If that`s ok - I will let someone more knowledgeable advise further.
Old 27-04-07, 08:51 PM
Club Sec/Rep Liason
Two possible causes spring to mind. The most likely would be a Plug/s or lead/s breaking down on the sickly bank.Try pulling leads whilst it is misbehaving to ascertain which plug/lead is the problem. Or a header/head joint leak could make it Pop on one bank, But more likely it would only show up on overun.
AK 427 351C T5wc
Old 27-04-07, 08:59 PM
Check for air leak on the exhaust, maybe tweak up the flage nuts.
Stan
Old 27-04-07, 09:10 PM
Check the underside of the distributor cap, probably damp.
If it is not that, replace everything.
Old 28-04-07, 07:20 AM
David Large's Avatar
I was having a similar problem recently and a new distributor cap and rotor arm worked wonders. Boyze pointed out to me the tracking line on the rotor arm!
cheers
David Large
Bald Surfer with a BRA 289
Old 28-04-07, 10:53 AM
kobra's Avatar
backfire
cheers
Ok thanks for ifo ill get to it this morning see what i can find . Regards Ray
Backfire BIGUNDIES General Cobra Discussion 4 19-05-06 10:58 AM
Backfire V8 BJC General Tech Tips & Questions 11 22-04-06 04:32 PM
Cause of Backfire Problem?? crendonman General Cobra Discussion 0 01-01-06 03:15 PM
Backfire Harry-G General Cobra Discussion 6 21-01-05 06:07 PM
Backfire Harry-G General Tech Tips & Questions 4 01-11-04 08:24 PM
