| RV8 camshaft timing I'm advised an easy method for in-situ cam timing is to set crank at TDC (using machined reference point on timing cover) and the measure with two DTI's full lift on both inlet and exhaust on No1 cylinder. Anyone tried this method?
__________________ Stan |
| Pete, Thanks for that - after I read my post I realized I was talking rubbish. What I meant to say was "equal lift between in and ex" not max lift. I think this method is called "splitting the overlap" and its supposed advantage is you don't need a timing disc.
| Quote:
How does it work then, is it that at TDC the exhaust and inlet valve are at equal lift during the overlap phase? I did have some problems getting hold of a timing disc, in the end I uesd a 360 protractor that I bought from WH Smiths!. It was quite large, maybe 6" diameter and worked very well. Regards, Pete |
| Ford Timing and Timing light | ldtopham | General Cobra Discussion | 9 | 12-02-05 03:28 PM |
| Camshaft Timing | sglover | General Tech Tips & Questions | 2 | 15-11-03 06:57 PM |
| Camshaft Timing | sglover | General Tech Tips & Questions | 10 | 12-11-03 05:52 PM |
| SBC Timing - 2 timing marks on damper | jonbillings | General Tech Tips & Questions | 14 | 09-10-03 07:37 PM |
| Z 28 Camshaft | choogh | General Cobra Discussion | 5 | 17-04-02 09:17 AM |
