Old 05-05-07, 07:12 PM
Rover V8 - Oil Pressure
Hi All,
Can anyone advise on what the minimum oil pressure should be. My RV8 has a pressure of around 30 psi when I start it up. After a little while the pressure drops as the revs drop. The gauge has just started to drop low down until I put my foot down and then the pressure picks up. I am just a little concerned about the pressure dipping. It did not do this when I first put the engine in but has just started doing it. any advise/ suggestions would be welcome.
Martsam
Old 05-05-07, 09:04 PM
ceejayjay's Avatar
My op is spot on at 35psi when hot at 2400rpm, But when idling at junctions if the tickover is below 800, it get lumpy and the op drops, not hugely but a bit. If its only doing that then I reckon you're fine. Oil made big differnece to mine. Much better on Valvoline Racing 20 50.
Old 05-05-07, 10:13 PM
Sidecarbod's Avatar
Re: Rover V8 - Oil Pressure
Originally Posted by martsam
Hi All,
Martsam
What does it drop to?
Mine also drops a bit at tickover, I think that its just over 30 then picks up to about 35-40 over about 2000 rpm. The temp of the oil makes a big difference along with its viscosity. I doubt that you've got a problem, I've heard that some rover lumps drop to 10-15 psi at tickover and still run OK.
HTH,
Pete
Old 05-05-07, 10:55 PM
If you have the standard cog type oil pump driven by the dissy then this is normal, half my SD1's the oil light would flicker at junctions.
It all depends on the age and condition of the engine. the best option is to fit an inermediate timming cover with the crank driven pump. my engine is 50 psi at idle and 55-60 on throttle.
john
WAHOOOOOOOOO: ON THE ROAD AT LAST.:drive:
Got my MSA Licence hillclimbs here I come.......wheeeeeeeeeee!
JUST NEED A TYRE SPONSOR NOW>>>>
Exhausts & headers made by Mark (fat boy northern)
Old 06-05-07, 12:18 AM
David Large's Avatar
My experience is that with a standard oil pump set up 15-20psi at hot tickover and 25-30 at 2500rpm is normal. I guess it depends on the type of pump, the pressure relief valve, the type of oil, the filter base replacement and.........the state of the engine, but these are low pressure engines.
cheers
David Large
Bald Surfer with a BRA 289
Old 06-05-07, 02:51 PM
Banned
RV8 oil pressure standard is normally at hot, 10 on tick over and no more tha 35 at rev's it's a high volume pump rather than high pressure.
With a Landy front cover and pump, MGB spring and moded I make 80psi on start up cold, 55 psi when hot and 25 psi on tick over.
Osgood
Rover oil pressure stevey Engine Tech Tips & Questions 0 10-08-07 08:43 PM
ROVER OIL PRESSURE stevey Engine Tech Tips & Questions 11 07-06-07 08:42 PM
Rover V8 Oil Pressure Adrian Engine Tech Tips & Questions 9 10-04-06 12:10 PM
Rover V8 oil pressure after winter lay over whp427 Engine Tech Tips & Questions 10 11-04-04 04:51 PM
Rover 3500 V8 - Oil Pressure kalto Engine Tech Tips & Questions 11 11-11-03 10:51 PM
