| Unilite Distributor Tonight worry has set in ahead of my first start up on Saturday. So tonights worry.... I have a 383 sbc stoker that has a Unilite distributor. This has no vac advance. I have fitted standard coil and ballast resistor set up, no electronic ignition box thingy. so engine builder says set static timing to 8degrees before tdc, he has done this and marked the distributor for me also. However when i run it up how does the timing advance change at higher revs. daft question maybe but I am learning on the job here. On the distributor instructions it says '' distributors with numbers .....etc etc have 24 degrees of mechanical advance at 3000---3200 revs'' is this my answer. I can't see what would move in the distributor to change the advance ?
__________________ David Clifford AK427, Tremec and Stroker. |
| Second thoughts. The base plate will stay where it is and the rotor arm will advance in relation to the weights. The base plate only moves on vacuum advance systems. Craig.
| Thanks I am going to turn this off shortly and go to bed up at 4am tomorrow morning so will sleep better now thanks and see you on Saturday.
| Mallory Unilite Distributor and first start. | cliffords | Engine Tech Tips & Questions | 42 | 31-05-07 06:26 PM |
| rover distributor v mallory unilite | oiler0 | Engine Tech Tips & Questions | 3 | 30-10-06 08:38 PM |
| SBC Distributor | garyholden | General Tech Tips & Questions | 6 | 14-07-05 08:44 PM |
| Mallory Unilite 4768901 dissy | wires | Engine Tech Tips & Questions | 4 | 10-10-04 07:47 PM |
| Mallory Unilite | beanpole | Engine Tech Tips & Questions | 3 | 04-08-03 09:01 AM |
