| Starter Motor - RV8 Hi Gents Just want a quick bit of advice re a starter motor in the Real Steel Catalogue - Part No AZN17792. Listed as a Range Rover starter, compact mini type, new Bosche starter with solenoid. Will this be OK for my 3.5 SD1 engine? Thanks Martin
__________________ GD427 Mk4 - Chassis rolling!! 3.5 RV8 - Engine in and running!! GD Chassis J0258. People who never make mistakes, never make anything!!! www.martins-cobra.co.uk |
| Sorry can't help but try www.racemettleltd.co.uk great piece of kit and it can be fitted with the solenoid in any position so can be kept clear of header pipes!
| Here is an E-Bay auction to the type fitted on my 4.6 Range Rover http://cgi.ebay.co.uk/STARTER-MOTOR-...QQcmdZViewItem Note that most, if not all Range Rover starters have the solenoid sticking straight out the side of the engine. Kind of 90 degrees to the engine block. This will probably cause clearance issues between the chassis and the solenoid. The SD1 starter has the solenoid sticking straight out the bottom so should give a bit more room. Craig.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 16 |
| Quote:
The starter in the Real Steal catalogue seems to have the solenoid on top, rather than on the side (like Craig suggested the Range Rover one is), or underneath as the original SD1 starter that I am replacing has. Is that going to be OK?? (putting the engine into a GD). Thanks Martin
| Just for reference I have attached a couple of pictures of an oiley old SD1 starter on a nice shiney new 4.6 block. As can be seen, the solenoid faces downwards. If the real steel one looks similar to this then go for it. Craig.
| Quote:
The Real Steel one is as the picture attached. As you can see the other way up.... Martin
| Martin That looks exactly like the one fitted to mine. I have the 3.5efi RR engine and it cranks it fine. Solenoid upwards suits my setup better. Got mine from a breakers and plenty of life in it still. Cheers
| Old Starter Motor | martin_t | Engine Tech Tips & Questions | 1 | 20-08-07 09:51 PM |
| Starter Motor | martin_t | Gardner Douglas Technical Questions | 1 | 14-08-07 07:20 AM |
| starter motor | v8 sam | DAX Technical Questions | 2 | 15-11-06 02:58 PM |
| starter motor? | jamesandlouisa | Engine Tech Tips & Questions | 12 | 27-09-05 05:58 PM |
| MCI Starter Motor | Miket | General Tech Tips & Questions | 16 | 06-06-02 10:34 PM |
