| Phil if your engine has a proper range rover sump it should take without oil cooler around 11 pints I think. Osgood |
| Agree about 10 to 11 pints if changing fliter too. About a pint remains stuck to everything unless you use a oil flush. These engines are high volume low pressure systems. Valvoline 20 50 Racing is best IMHO giving best OP at all temps. They do not like modern oils - 10 30's etc. Chris |
| I think 5.7 ltrs is about right. I use 20/50 I think Duckams or castrol. Dont forget to prime the system if pre 1993, serpentine engine, I think. I did'nt once. Ouch, but if you've got oil pressure you should be ok. |
| SBC 350 Oil Capacity? | garyholden | General Tech Tips & Questions | 4 | 23-03-07 11:12 PM |
| Pilgrim with Rover V8 Coolant Capacity | perky | Pilgrim Sumo Technical Questions | 2 | 17-06-05 10:12 AM |
| Oil capacity | chiffer | General Tech Tips & Questions | 0 | 19-04-05 12:36 PM |
| Oil capacity | G4NLZ | General Tech Tips & Questions | 3 | 17-09-04 08:45 AM |
| Rover SD1 Gearbox Capacity | alastaid | General Tech Tips & Questions | 4 | 31-07-01 01:52 PM |
