| Hi I had a real job getting the Crankshaft pulley bolt off my Rover engine when I took the engine apart, now I can't tighten it enough putting it back on!!! The manual says 190-217NM which is dam tight!! When I try to tighten it I turn the engine. Didn't know if I jammed something in the flywheel I may damage something putting that much pressur on it? I have the clutch on but can take it off if necessary. Any suggestions or experiences would be gratefully recieved. Cheers Martin
__________________ GD427 Mk4 - Chassis rolling. 3.5 RV8 - Engine in and running. MK4 Body ordered (in black)!! GD Chassis J0258. People who never make mistakes, never make anything!!! www.martins-cobra.co.uk |
| Really tight!! Whatever you do, make sure it's really, really bl***y tight. Mine wasn't and over time it fretted back and forth and widened the keyway, making the pulley scrap. As it is a P6, a replacement pulley was hard to find. It also picked up on the crank and when I came to fit a new pulley, I had to file the deposited metal off to get the new one on. Luckily the crank is harder than the deposited metal and the process was fairly easy. There you go. I suggest waiting until the wheels are on and nipping it up against the hand brake, just don't forget to do it.
__________________ 1985 DAX 427, Black, no scoop, no brightwork, no paint, 15" Revolution split rims, BFG boots, 3.5SP6RV8 with modified 4.2 heads, modified SU's with K&N, Kent 180 over Rhodes lifters, SD1 chain cover / P6 water pump, SS headers & side pipes, Jag/Jag with uprated lowered springs, AVO shocks, Red Dot spiro discs & fast road pads, Toyota Supra CR high 5th box & special clutch. Looks like a dogs dinner, drives like it's taken 20 years to develop! |
| Hi guy's, Sorry I interrupt this Rover thread but reading about the torque at the crankshaft damper bolt amount of torque mentioned above 190-217Nm that is a lot, I did check my Chevy specs and say that a torque of 63 Ft-lbs = 85Nm should be applied. Now I get nervous, is the 85Nm correct? I did found that information on the net and like I say it is for a Chevy. Please let me know if this is correct. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| crankshaft pulley removal | clive a brown | General Cobra Discussion | 11 | 06-04-07 11:25 PM |
| Crankshaft Damper & Pulley | steamyrotter | Engine Tech Tips & Questions | 3 | 27-01-07 10:05 PM |
| Cant undo Crankshaft Pulley retaining bolt | martin_t | Engine Tech Tips & Questions | 8 | 20-04-06 09:49 PM |
| Crankshaft Pulley Fixing / Chevy 350 | MickyB | General Tech Tips & Questions | 7 | 20-04-05 09:56 AM |
| crankshaft pulley bolt slackening | Kassi | Engine Tech Tips & Questions | 3 | 29-03-05 06:40 PM |
