Old 03-10-07, 09:53 AM
Yellowbelly's Avatar
Exclamation Cleveland oil leak
What is the best way to seal between the inlet manifold and valley pan engine webbs? The rubber seals supplied in the gasket set always seem to squeeze out when you torque down the inlet manifold. I have tried glueing them in place first as recommended by real steel but this doesnt seem to work. The rear of the engine appears to be worst. Any advice gratefully appreciated.
Old 03-10-07, 10:54 AM
RTV Silicone - throw away the rubber seals, lay down a good thick bead of RTV, drop the manifold on in one go (i.e. don't expect to move it around to align - sometimes a couple of temporary studs in the bolt holes will help) and leave for 24 hours minimum.
Ensure all surfaces are thoroughly cleaned and degreased first.
Then Robert will be the sibling of one of your parents.
Old 03-10-07, 11:25 AM
dingocooke's Avatar
Ive never had a problem with the rubber end gaskets, but as wilf says the trick is to get everything scrupulously clean first. I leave the rubbers/adhesive to set properly 1st before trying to put on the manifold.
The silicone bead method is very popular and effective, especiially where blocks and heads have been decked. Cleanliness is your friend here, and dont be so liberal with it that you end up with surplus silicone where it can be washed into the oil system-expensive!
If you have had your block decked or your heads faced and you have not machined the manifold to suit, that could be why your pushing the gaskets off?
There is a chart somewhere on the Edelbrock inlet manifold site that tells you how much to take off the inlet manifold.
Steve
We're here for a good time...
Old 03-10-07, 05:00 PM
Dutch Paul's Avatar
Oh I`m so tempted
Old 03-10-07, 05:20 PM
Just this once..............don't give in to the temptation.
Old 03-10-07, 05:21 PM
dingocooke's Avatar
eh?????????
Steve
Old 03-10-07, 05:23 PM
Oh come on, keep up at the back - you just know what he is going to say, and it would be a firm recommendation to swap to a GM product.............not that they never leak oil of course.
Old 03-10-07, 05:24 PM
dingocooke's Avatar
sorry I missed that. must keep awake, must try harder
Steve
Old 03-10-07, 05:45 PM
Dutch Paul's Avatar
Originally Posted by wilf View Post
Oh come on, keep up at the back - it would be a firm recommendation to swap to a GM product
I didn`t say a word.
Old 03-10-07, 05:56 PM
Maybe not, but when you do, it's usually the same words........every time.
Cleveland 2V in need of TLC 427FE Parts for sale 3 25-11-07 09:37 PM
600Hp Cleveland ! 427FE Parts for sale 5 04-11-07 07:50 PM
351 Cleveland part req Philip de Cadenet Wanted Adverts 3 25-09-07 07:54 PM
351 Cleveland into a Sumo colinsw854 General Cobra Discussion 6 05-11-05 11:48 AM
Tremec T56 to Cleveland miller General Tech Tips & Questions 0 16-10-03 08:29 PM
