| I would check to confirm the fuel pump is running after the engine has started. Does it run through an oil pressure switch cut out? Craig.
| Is it possible the feed for the fuel pump comes from the starter circuit instead of ignition circuit, by mistake? Just a thought.
| Just ran it and the same happened, but when it stalled the pump was still working so I am under the assumption it does work when running plus it does run when the oil pressure switch is out.
__________________ C an O nly B e R eal A drenalin Sumo 3.5 RV8..... megasquirt... |
| I know of at least two RV8 sumos where the charge light stays on if you fire up the motor but don't take the revs over about 2k rpm. Once the light goes out it will stay out even at tickover. I guess the alternator just needs to be spun quick enough to get the thing working. Whilst the light is on the battery definately is not being charged, once the light is out my battery has 14.5v across it at tickover. Can't help with your injection issue.....oh wait, stick a carb on it! HTH, Pete
| Quote:
I am sure the battery as died due to lack of use.. 2yrs at least!
| Hi Stu, The ignition lamp needs a 12v feed from the alternator and a 12v supply to the lamp, when not running the alternator feed is grounded thus the lamp is lit, when running the feed changes to +12v therefore causing lamp to go out. When sorting out the wiring on my pre-owned sumo i found that the feed from the alternater had been wired incorrectly. Secondly have you checked the fuel filter this will need to be changed frequently as the sumo tank seems to quite dirty, just a thought. Hope this helps. Gary, No problems!!! only solutions!! |
| Issues List | robert | General Cobra Discussion | 33 | 16-12-07 12:30 PM |
| Security Issues !!! | luke | General Cobra Discussion | 18 | 02-07-05 12:49 PM |
| Old Issues of SnakeTorque | BlackRam | General Cobra Discussion | 2 | 02-08-04 02:32 PM |
| AOL Browser Issues | robert | Admin Announcements | 0 | 22-06-04 02:41 PM |
| Login Issues | robert | Admin Announcements | 4 | 07-03-02 04:48 PM |
