| RV8 Spark plug thread size. Yes I know Im always asking what thread is this and what thread is that, but Im at work, its dark when i get home and i usually only come out to play at weekend. So I need the thread size to buy a compression tester to check all is well cheers Ben |
| thanks again Craig Ben |
| Many compression testers don't screw into the plug thread anyway - they just have a rubber bung that you have to press tightly into the hole.
| mmm ok, do you turn the engine over by hand or via the starter? |
| Starter, and with the throttle wide open. Remove all plugs. Disable ignition! Details here: Engine Compression Testing
__________________ My opinion is worth exactly what you paid for it. CRENDON - go on, you know you want to! Last edited by wilf; 27-11-07 at 10:15 AM. |
| Cheers Wilf, very helpful as per normal |
| They do, but they are useless if you are on your own or the plug hole is burried in the engine like on a Ford Zetec or down by the bulkhead like on my Cob. My advice is to buy a screw in one every time and make sure it has a pressure releif valve so that you can see the max pressure you are achieving.
__________________ 1985 DAX 427, Black, no scoop, no brightwork, no paint, 15" Revolution split rims, BFG boots, 3.5SP6RV8 with modified 4.2 heads, modified SU's with K&N, Kent 180 over Rhodes lifters, SD1 chain cover / P6 water pump, SS headers & side pipes, Jag/Jag with uprated lowered springs, AVO shocks, Red Dot spiro discs & fast road pads, Toyota Supra CR high 5th box & special clutch. Looks like a dogs dinner, drives like it's taken 20 years to develop! |
| spark plug gap | colin henry | Engine Tech Tips & Questions | 3 | 19-01-07 05:49 PM |
| Spark Plug Reading | Sidecarbod | General Tech Tips & Questions | 2 | 02-07-06 07:29 AM |
| spark plug gap | chiffer | General Tech Tips & Questions | 4 | 12-06-06 10:58 AM |
| Spark Plug Info | mikey | General Cobra Discussion | 2 | 05-06-06 09:30 PM |
| Spark plug gap | pat b | General Cobra Discussion | 2 | 28-11-04 11:48 AM |
