| Quote:
I've seen the above stuff come up on fleabay now and again. If you can't wait that long JRV8 or BAE or Realsteel could supply the bits. (Infact there is a new version of the 500 carb that has more control over the secondaries, I'd go for that if possible). If your car has not been SVA'd yet then you will have problems getting an EFI block through the emissions with a carb. HTH, Pete
| There's a kit on ebay just now that has all the bits you require excluding the fuel pump: Rover V8 Edelbrock 500 Carb, Intake & Air Cleaner Kit on eBay, also, Rover MGF, Car Parts, Cars, Parts Vehicles (end time 17-Mar-08 16:12:57 GMT) CeeJay.
__________________ Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out... |
| Quote:
I don't know much about the SVA but I believe that you have to prove the age of the block, after a certain date the engine has to comply with certain emission levels. (It might not even be allowed to use a carb regardless of how well it is setup). Things can get really bad if the block is very new as you will be forced to run CATS People do use the EFI setup and manage to get it working in a cob so it might be worth looking into that. I would not fancy having to stick CATS on it though! Pete
| Before you scrap the engine, determine its age. I found out the year of manufacture of my (previous RV Right - I'm off to try refitting my clutch. CeeJay.
| As it's a 3.9 litre engine that means it will be post 1990. If it's and early one you might be OK with the emissions but later models will need the Cats and EFI. Fit a 3.5 engine to start with. They can be brought for a couple of hundred quid from E-bay. Craig.
| Craig just had a look on ebay and your right theres loads on there for around a couple of hundred quid but not sure which one is best? Some are out of range rover and some defenders some sd1 and some unknown? Any advise would be gladly welcome... ![]() |
| rover 3.9 conversion kit | viperjim | Parts for sale | 3 | 03-10-07 10:23 PM |
| alternatives for carbs on a standard 3.5 v8 rover | Andy Badger | Engine Tech Tips & Questions | 7 | 18-04-07 08:51 PM |
| Rover Clutch Conversion | beanpole | General Cobra Discussion | 1 | 27-07-05 12:20 PM |
| Rover / Chevy Rocker cover conversion | perky | Engine Tech Tips & Questions | 9 | 30-04-04 02:57 PM |
| Rover V8 Cable Clutch Conversion | Ranger Bob | Engine Tech Tips & Questions | 1 | 19-04-04 07:30 PM |
