Me again.
Here's a couple of picture of my rotor arm. Can you see the black lines running out from the centre where the cap contact it made? Do you reckon the dust may have caused tracking to the two bolts holding the rotor arm in place? Craig.
Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 14
If you have not got it sorted and you have a Holley or similar carb I would just check the tightness of the fuel bowl securing bolts. It is very common on carbs up to 3 or 4 years old for the screws to slacken or for the gasket to settle. All you need is a microscopic gap and the fuel bypasses the gasket causing an enrichening effect. Bit like having a choke slightly out on a hot engine (for those that can remember chokes) (or magnetos in Wilfs case). This particularly happens when the car has been stood for a while (as in months) and then started. Over the length of a run as the carb warms this seems to bring it on. After a few years it seems to stop happening. For the sake of two minutes it is worth a shot - I remember Stoneleigh about 8 years ago where it sorted out about 4 cobras that were running horrible on tickover - it had been put down to electrics or cam. Mike |
Did you check the timing to see if it slipped. miek |
No, Haven't checked the timing yet but will give it a go at the weekend.
I am thinking of changing my spark plugs as I have had previous problems with Champion spark plugs in my Range Rover. I found the NGK equivalent to the ones I have fitted but I have read about different temperature plugs? Any good recommendations for a 350 running 10:1 CR and Edelbrock aluminium heads? Craig.
I have attached the table for NGK choice which makes it simple NGK spark plugs symbol code eg if you were to choose iridium then it would be a BPR-5EIX depending on if you are using a capacitive discharge or other you may want a plug with a larger gap so that the electrode and groung remain as near parallel as possible. In that case you would use a BPR-5EIX-11. Just choose the type of nose you require depending on what you want to spend and use the relevent symbols in the latter part of the plug type. If you want to check if you have got it right just post. Just a last comment - a common thing is for owners to look at tables that give compression, head type, compression ratio etc. This can lead you to a heat range around 7 quite easily. The reality is that if the car is not being driven hard all the time, this can lead to fouling on a cold plug. Better to get the 5 or 6. If I were a betting man the 5 would be the one for road use. Hope this helps Mike |
Many thanks Mike.
That helps a lot. I did a comparison search for the Champions I have at the moment and the NGK equivalent is the BKR5E. I will take a look for some Iridium ones though And get the BPR-5EIX-11 Wonder if Halfords sell them? Thanks again. Craig.
These guys are pretty competitive: NGK Iridium Sparkplugs List All the best Mike |
16mm Hex is useful to give a bit more clearance around the cylinder head.
BKR-5EIX-11 It is then Many thanks Craig.
| Something slightly different | arny | The Cockpit | 0 | 24-10-06 10:13 PM |
| Slightly o/t. V8 in a TR6 | simon | General Cobra Discussion | 12 | 05-04-06 04:45 PM |
| Rough Idle | Glyn_Turner | General Tech Tips & Questions | 19 | 21-09-05 12:06 PM |
| Rough Running | cheepskate | Pilgrim Sumo Technical Questions | 6 | 18-04-04 12:27 PM |
| Rough Running Chevy 350 | Andy427 | General Tech Tips & Questions | 11 | 17-09-01 09:22 PM |
