  #51 (permalink)
Old 01-05-08, 07:37 PM
Veteran polisher.
Thanks again for all the replies to this thread.
I have now finished fitting £150's worth of new fuel filter and piping to my car. It's amazing how a few metres of braided pipe and aluminium end fittings add up.
Anyway, Removed the old fuel filter which was one of those hated glass body filters that was placed before the pump. It was full of fuel when I removed it and I expected it to run out. It didn't and required compressed air to blow the fuel out. It was definitely blocked!
I cleaned it anyway and tried blowing through it and it still seemed horribly restrictive.
I fitted the new Fram fuel filter and plumbed it all in using spedflow braided steel hose and aluminium hose ends. After turning the ignition on I thought it wasn't working as the pump seemed to be twice as noisy and running twice as fast as before. I disconnected the pipe from the carb to see what was happening and when I turned the ignition back on I found out how far a stream of petrol can go!
Moral of the story is, Use those glass filters on your lawn mowers only. Not fit for anything else.
If we get a dry day over the weekend I will give it a blast.
Polishes to date = 17
  #52 (permalink)
Old 01-05-08, 07:45 PM
Per Ardua Ad Cobra
Originally Posted by craggle View Post
Another good point Wilf.
I haven't used the car for a while so will give it a look over tomorrow night.
I'm more and more tempted to get an EFI kit for it though. I guess these don't suffer from icing?
I know EFI has been considered "gay" but I already have a Dax with a Chevy and cream leather interior. If it's going to be gay, It may as well be 100% Gay!
It's only Pete who thinks EFI is GayFI Craig. Go for it. Reduced emissions, Smoother running, better fuel consumption.... etc
Hopefully will start my engine fot the first time this weekend with EFI fitted!
Mind you if it doesn't start I won't let Pete know. I'll never hear the last of it
Nick
Remember - Careless torque costs lives.
  #53 (permalink)
Old 01-05-08, 07:52 PM
Clarkson's Avatar
Speed junkie
How about a road test to Stoneleigh??
David
2nd baby due 23rd Jan.
  #54 (permalink)
Old 01-05-08, 10:13 PM
Sidecarbod's Avatar
To Late Nobby, I've read the post.
I'm back in Blighty on Saturday, I'll be round to watch the proceedings. (I'll bring some spuds to throw on the fire )
Pete
  #55 (permalink)
Old 02-05-08, 04:11 PM
Per Ardua Ad Cobra
Pete
Bitch.....
You'll be jet lagged out of your mind wont you? I was last weekend and time difference was only 5 hours. Las Vegas is more like 7 hours behind?
Still you can hold the fire extinguisher if you like
Nick
  #56 (permalink)
Old 02-05-08, 04:58 PM
Noel's Avatar
Any of you lot going to Stoneleigh???
Noel
Sumo,
BAE Chevy 4??ci /Roller cam
Gallery: http://www.cobraclub.com/gallery/sho...63&page=0&sort=
  #57 (permalink)
Old 05-05-08, 05:43 PM
Veteran polisher.
Just a word of advise.
If you use braided steel tubing and decide to cut it with a thin disc grinder make sure you clear out the pipe afterwards.
I made it to my friends house fine today but then when I went to re-start it, It didn't want to fire.
After removing the air cleaner I could see too much fuel running down the barrels. Luckily my friend has a well equipped work shop so we took the top off the carb and found rubber residue in the float chambers and in the needle valves. Once cleaned it started fine and drove home well.
I will check again tomorrow night to see if any more has made it through.
Runs very nicely now with the new fuel filter and spark plugs. Seems a lot smoother with more progressive power.
  #58 (permalink)
Old 05-05-08, 05:59 PM
Wilburn's Avatar
Barts Elephant? Like the Simpsons do we?
Thanks for that. I am currently changing my fuel filter for a much bigger one which will hopefully collect water in the bottom. The dax tank has a sump on it so I guess any water that got in there would be first to go out the inlet to the engine.
I will let you know what I find in the filter when I get the old one off.
Fuel filter ? ........... I don't believe I have one of them!
Paul
DB Replica build 98 - Dax De Dion
David Clarkson - 383 stroker
Barry Grant speed demon carb
Roller Cam
Edelbrock performer air gap inlet manifold
Visit my Cobra photo gallery at paulwilburn.co.uk
  #59 (permalink)
Old 05-05-08, 06:38 PM
Veteran polisher.
You serious Paul?
You should have a filter pre-pump to protect it from any dirt that may come from the forecourt tanks.
If Dave built the car it will have a filter. Maybe he will post here and let you know where it is.
  #60 (permalink)
Old 05-05-08, 06:55 PM
Wilburn's Avatar
mmmm. I'm 99.9% sure it ain't got one.
Have I got one Dave?
Paul
Roller Cam
Something slightly different arny The Cockpit 0 24-10-06 11:13 PM
Slightly o/t. V8 in a TR6 simon General Cobra Discussion 12 05-04-06 05:45 PM
Rough Idle Glyn_Turner General Tech Tips & Questions 19 21-09-05 01:06 PM
Rough Running cheepskate Pilgrim Sumo Technical Questions 6 18-04-04 01:27 PM
Rough Running Chevy 350 Andy427 General Tech Tips & Questions 11 17-09-01 10:22 PM
