Old 20-04-08, 08:30 PM
Veteran polisher.
Slightly rough running.
Hi All
Seeing as it was such a nice evening I decided to take the car out and fill it up with fuel. Journey there was uneventful and I'm glad to say the car still has the potential to scare me!
On the way back however, I decided to go home the long way and about 1 mile from home the engine started running quite rough. It would tick over and run to about 2000 revs fine, but above that it and when under load it hesitated and popped through the exhausts. Made it home OK at reduced revs.
The same type of thing happened in the summer last year when it stopped on me. I wiggled a few connectors on the distributor and it started and ran fine after that. I replaced the connections on the distributor for the proper plugs and didn't think anymore about it.
Any ideas, HEI coil breaking down with heat, Carb icing, Fuel mixture being temperamental?
Chevy 350 with Edelbrock performer RPM package and standard HEI distributor.
Polishes to date = 17
Old 20-04-08, 08:40 PM
rocketmut's Avatar
Shit! that wasn't right.
On our return journey from the northern meet a couple of sundays ago AKMikes carb was icing up and chatting to him last nite he said that Lee Topham had the same on his way down to GD. 350CHEV & 351C FORD.
BOUT A NINE ON THE OLD TENSION SCALE THERE RUBE!
DB DAX DE-DION NO 117, HUDDART 396W STROKER,+ HARDTOP.
Old 20-04-08, 08:50 PM
Veteran polisher.
Quite possible I guess. It looked a nice evening but it was cold once going.
I pulled the air cleaner off as soon as I got home but couldn't see anything wrong. I guess once the engine is turned off any ice will melt instantly due to the heat coming back up through the manifold.
I will try it again some time and see if I have any more problems.
Old 20-04-08, 09:05 PM
..or moisture under the distributor cap.
Old 20-04-08, 10:58 PM
Veteran polisher.
Another good point Wilf.
I haven't used the car for a while so will give it a look over tomorrow night.
I'm more and more tempted to get an EFI kit for it though. I guess these don't suffer from icing?
I know EFI has been considered "gay" but I already have a Dax with a Chevy and cream leather interior. If it's going to be gay, It may as well be 100% Gay!
Old 20-04-08, 11:20 PM
Clarkson's Avatar
Speed junkie
Yes they do, unless it has a water heated throttle body.
David
2nd baby due 23rd Jan.
Old 20-04-08, 11:42 PM
Clive's Avatar
Very unlikely but it might be bad fuel. Water contaminated perhaps.
Cheers, Clive
Old 21-04-08, 06:07 AM
David Large's Avatar
Is there a condenser on your car?
David
David Large
Bald Surfer with a BRA 289
Old 21-04-08, 08:03 AM
Veteran polisher.
No Condenser.
All in one HEI Distributor with electronic ignition and the coil mounted in the top of the distributor cap.
Might change the fuel filter as that hasn't been done for a while and the problem appeared after I had filled the tank up.
Tempted to get an MSD distributor cap and coil as the one on there looks completely standard.
Old 21-04-08, 10:26 AM
hei and heat
hi craig,
i'd be suprised if you have heat issues with a hei...unless the amplifier was installed without the correct heat conducting paste underneath it..(?)
- i ran my 77 'vette for two years in the saudi heat without any heat issues...
@50+ degrees C
whilst out there i did pop in a new amp module and leads, plugs etc but that was just because they were cheap..ha ha
seems too much of a coincidence you'd just refuelled..
(plugs and leads would be another matter though)as these would be more likely to missfire if you open her up as pposed to ticking over and 'missing' ,
(more to do with seeing the actual comp. ratio dynamic as opposed to just static ??)
but again unless they were all contaminated or fouled not really too likely.
could have been condensation in the tank of couse and the refill stirred it up??
hope you get to the bottom of it though
neil
Something slightly different arny The Cockpit 0 24-10-06 11:13 PM
Slightly o/t. V8 in a TR6 simon General Cobra Discussion 12 05-04-06 05:45 PM
Rough Idle Glyn_Turner General Tech Tips & Questions 19 21-09-05 01:06 PM
Rough Running cheepskate Pilgrim Sumo Technical Questions 6 18-04-04 01:27 PM
Rough Running Chevy 350 Andy427 General Tech Tips & Questions 11 17-09-01 10:22 PM
