Old 27-04-08, 04:28 PM
Andy302's Avatar
Red face Leaky Mr Gasket 5807 Head Gaskets
After yesterdays less than perfect dyno run I've set about trying to find out where my oil and water got acquainted. Prime candidate was the manifold valley seal but after tearing it down that looked good and I couldn't see any water path. So I hunted the old internet and on the Ford muscle forum I found comments about the 5807 head gaskets I have used. Many saying they dont work so well on older blocks. So I took the decision to pull a head, glad I did. There was water all over the gasket surface head side and when I took it off the block on the block side as well. In some places you can see black deposits from combustion has crept under the gasket.
I cant be 100% sure if there is where it went wrong as Im not experienced enough but the gasket does not look in a good state for one dyno run. The old thing a took off initially looked healthier!!
Anyway its taken 4 hours to wind the clock back 2 years on my build!
Anyone got any comments?
Cheers.
Andy
www.andysgd427.blogspot.com
Old 27-04-08, 08:24 PM
Clarkson's Avatar
Half arsed=half fast!
Are those gaskets thin steel shim type?? If they are,they are also unrelible on Chevys. Replace them with a felpro gasket and it should be ok.
David
SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign.
http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself"
Old 27-04-08, 08:57 PM
Andy302's Avatar
Wink
Hi David,
Yes I think they are, Im sure you are not supposed to get water all over the deck surface under the gaskets!
As you say Ill be ordering a set of Fel Pro 1011-2's tommorrow! Other than that Im right chuffed with my little motor, Tim said it has a nice smooth idle and it certainly just sat there burbling along.
Andy
BB code is On
Head Gasket - Not Cob Related Martyn-ak427 General Cobra Discussion 30 17-01-08 10:13 PM
Head gasket sealant Sidecarbod General Tech Tips & Questions 2 09-05-06 12:56 PM
Head Gasket set for 302 Jason Engine Tech Tips & Questions 4 20-12-05 07:58 PM
RPI head gaskets jeff General Cobra Discussion 4 26-04-05 08:23 PM
Head gasket advice hfbradley01 Engine Tech Tips & Questions 14 10-02-05 06:12 PM
