Old 30-04-08, 09:37 PM
Sideways Sideways is offline
Ford V8 but what gearbox ??
Hi there I'm after advice......
I intend to put a Ford 302 or 351 in my Pilgrim which is running Granada Scorpio diff and looking to source a manual gearbox
Unfortunately I'm hearing mixed messages i.e don't fit a 4 speed box as the car will appear to be running out of steam i.e on motorways, it must be a T5 or Tremec.
Then theres the ah... just change the ratios in the diff and you can put in a 4 speed.
Has anyone any experience or can point out what are the ways to ensure the motor, gearbox and diff all work in harmony to ensure a good rev range and driveability.
I am trying to a source a cost efficient means to do this so please no put in a £2.5k gearbox as thats the easy way if I had the funds !
Thanks in anticipation.
Sideways.
Old 30-04-08, 11:21 PM
TINKA TINKA is online now
Stick in a Getrag gearbox really smooth and relatively easy to get hold of. AK will do you an adapter kit. As for the diff ratio I believe there is one about 3.6-1 which would do most of the jag kits using this setup run a diff with a ratio of either 3.31 or 3.54-1 The 3.31 is more for cruising and the 3.54 is more for acceleration but either is good. HTH
Old 02-05-08, 09:19 PM
Hi Tinka,
Can I ask more advice please...I should collect a 302 V8 next week and have sourced a Getrag gearbox. Now need a clutch, flywheel, clutch fork and bell housing.
I have seen you comment that there are two bellhouse sizes...any ideas what I should source to ensure a fit to a Getrag through thr AK adapter unit ??
Thanks,
Sideways.
Old 02-05-08, 09:59 PM
Iain's Avatar
Iain Iain is offline
Originally Posted by Sideways View Post
Hi Tinka,
Thanks,
Sideways.
Hi,
I've got a Ford 302 and have just fitted a Getrag gearbox.
I believe you can get the clutch and pressure plate from Real Steel and maybe the fork and release bearing too.
The bellhousing is related to your flywheel. There is a 157 tooth and a 164 tooth flywheel. Get the wrong pair (as I did) and your starter won't engage the flywheel (or possibly worse!). My original setup had a 157 tooth flywheel on a bellhousing suited for a 164 tooth flywheel.
Just be cautious (check exactly what you are buying) as you purchase your parts and you'll be fine.
Cheers...
Iain
http://www.fake-snake.co.uk/
Classic Replicas Viper
SVA'd Nov 2007
Old 02-05-08, 11:29 PM
I think Iain has covered most of it. I have a bell housing for sale that is for the 164 tooth flywheel, AK will sell you an adapter kit with all you need in it. You would need to get a clutch fork though as I don't have one of those but Reel Steel sell them now. If you do go this way and want my bell housing let me know, but a phone call to AK and they will tell you all you need to know, they are a really friendly bunch at AK.
Old 02-05-08, 11:31 PM
I will be at Stonleigh both days if anybody is interested in the bellhousing.
Old 03-05-08, 02:40 AM
viperjim's Avatar
viperjim viperjim is offline
hiya sideways , or should we call you si , don`t know if you`ve seen it but someone in the classified section is selling a sh##load of stuff that might help you out , just thought i`d let you know and good luck with the build
Old 03-05-08, 01:05 PM
Hi Viper Jim,
Warrington eh...I'm in Lymm.....
You can call me Si but David is fine...
I'll check out the classifieds right now.
Regards,
David.
Ford V-8 Toploader Gearbox trans Parts for sale 0 15-04-08 07:09 PM
Big block Ford/Gearbox John k General Tech Tips & Questions 8 15-09-07 09:06 PM
Ford 351w / Gearbox rudy Pilgrim Sumo Technical Questions 10 24-08-05 07:25 PM
ford 302 v8 engine & gearbox BIGUNDIES General Cobra Discussion 0 30-09-04 07:47 PM
Gearbox for Ford Cologne Bluenose General Cobra Discussion 2 20-11-02 09:38 PM
